Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Picture is concave on top and bottom. With ed and green ghosts.Worked fine, turn set off and on about 15 minutes later and picture was as described. Help!
  • 1 more comment
  • ddaschner Apr 03, 2008
    Thanks, I'll do it!
  • emoretech Apr 05, 2008
    Mines just went out Thursday 4.3.2008 and idea of the cost to repair?|?
  • phil_hubbert May 11, 2010
    Are these chips on the replaceable
    Samsung AA95-00705A Deflection Board. If so can I just unplug this board and plug the new one in?
  • 58 Answers
The convergence chips in your tv have gone out. They control the three picture tubes and align them so that they create one picture on your screen. I recomend having a qualified technican replace them and realign you convergence. Thanks.
Posted on Apr 02, 2008
I've been having this problem for a while. when I'd turn the tv on I was able to watch it for about 15 minutes. suddenly the picture and voice would turn off, but the green power button was still solid...
Sounds like it may be a power supply issue. I don't know what "modules" the tech replaced, but I would have advised you to scrap the TV for a newer model as they can get pretty expensive to find and replace parts of the older rear projections. Sorry I can't be more help to you.
Feb 04, 2010 | Televison & Video
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Picture is concaved and all the colors are off.
you will need to get a convergence done and the resistors on the conversion IC's checked and bad ones replaced
electech
Oct 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
61 inch proj. warped concave picture.
Josh Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom.. Bill premtech@willapabay.org
Jun 14, 2007 | RCA P61960 61" Rear Projection Television
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
191 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
