Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint side by side frig-no water, no dispenser lights, ice yes, but no dispense
Comment by onetoof, posted on Apr 01, 2008 Do you think using a voltage meter to test the incoming wires to the dispenser board might help narrow it down to which board is causing the problem?
On a scale from 1-10, how probable do you think the issue is with the dispenser board. Thanks, onetoof
  • 1,314 Answers
Disp bd most common on ge check for a loose connection first now at one time ge was giving free disp bds but that may be over but still worth a call to ge technical
Posted on Apr 02, 2008
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from
Oct 01, 2015 | Frigidaire Refrigerators
I am not able to get water to dispense from the cold water spout. I have checked the water line and am get water to the source. I opened the line splice at he bottom of the freezer door and I have water...
The water line in your freezer door is frozen. Make sure the freezer setting isn't too high above midpoint. If you unplug the frig. and crack open the freezer door for a couple hours it will thaw out. Good job on posting description.
Sep 25, 2011 | Hotpoint HSS25GFP Side by Side...
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs long ago have you changed them?
Jul 18, 2008 | KitchenAid KSCS25FKSS Side by Side...
I bought a Hotpoint refrigerator in early 2004 but did not have it delivered until late 2005. After about a year the water dispenser quit working. Ice dispenser would just drag at times. Then the water...
ngfam1 At your service!
I came to your service on some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our site!
Bless, You ngafm1
Jul 09, 2008 | Hotpoint HSS25GFP Side by Side...
Ice Maker? Control Panel?
ARE the dispensing?? your post says yes but if not the 1st thing is to check to see if the water is turned on.. also the valve in the rear of the unit maybe bad let me know
Oct 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
Water dispenser keeps running
Allen, one of two things here. The dispenser target switch has gone bad or the actuator arm is not releasing the switch. Remove the front cover by using a small screw driver to unlock the tabs at the bottom. Slide the panel down and out. Disconnect the wire harness. Remove the 4 phillip screws in the door dispenser housing. Slide the housing out and disconnect the target switch and light connectors. Now you can spread out the locking tabs and examine the switch. If this all checks good, then the board is the back.
Dec 11, 2006 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
76 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
