Question about Canon Powershot SD450 / IXUS 55 Digital Camera
E18 pops up
Hello i have a canon powershot sd450 the lens comes out but it bleeps and i get a black screen and e18 pops up on the bottom. what do i do?
  • 22 Answers
An E18 error refers to a problem with the lens. Generally you receive this error if the lens is stuck, which often happens if you drop your camera while the lens is extended or if something like sand or dirt gets inside the lens barrel/gears. Your situation, however, sounds different since the lens seems to extend before giving the E18 error.
If the lens is fully extending before giving the E18 error, you most likely have a problem with the lens sensor located around the O-ring inside your lens barrel... either the sensor itself is damaged or the little plastic piece on the O-Ring that triggers the sensor is broken. If that's the case, there is nothing you can do yourself unless you feel like taking apart the entire camera and finding a replacement piece.
If the lens only comes out a little bit and is not fully extending before giving the E18 error, it sounds like something is making your lens get stuck. If you've recently been to the beach or a park where there is sand, try using a can of compressed air and blow it into the little gaps in the lens barrel... you may be able to blow the sand/dirt out, solving your problem. If the air doesn't work and you feel comfortable taking apart your camera, you can get to the gearbox and manually retract the lens by following my instructions below. Otherwise, I'd suggest a repair shop.
WARNING: TAKING APART YOUR CAMERA VOIDS THE WARRANTY AND CAN BE DANGEROUS! The capacitor that charges the flash can still hold enough voltage to give you a massive shock even when the battery has been removed for some time. Please only attempt to disassemble the camera if you feel comfortable doing so. I accept no liability for anything that happens should you follow my instructions below.
In order to open the camera you will need to remove six screws on the outer casing (2 where the wriststrap ties on, 2 on the opposite side, and 2 on the bottom). After unscrewing all 6 screws, pull the back and front casings off from the bottom out, as there is a clip-hinge on the top next to the shutter button that needs to disengage before you can fully remove the casing. Once the casing is removed, there is one screw holding in the flash apparatus, on the side. Remove it and carefully bend back the metal cage around the flash apparatus and pull it up. The flash will still be attached to the camera with a pair of wires (yellow and black) and a ribbon cable... leave those in place. Please be CAREFUL when handling the flash because the capacitor (the big black thing under the flash) can hold enough voltage to give you a severe shock even with the battery removed. Underneath where the flash was you will see a multi-tiered black piece of plastic... this is the gearbox cover. Remove the three screws from the cover and carefully lift the cover off the gearbox. Inside will be a motor shaft and 4 gears (2 white, 2 black). Remove the BIG black gear closest to the lens. Then temporarily replace the gearbox cover. With the big black gear removed, the lens should freely glide in and out if you push or pull on it. Do this several times in order to clean out any gunk that may have gotten into the grooves of the lens barrel. Then, open up the gearbox, replace the black gear, and screw the gearbox cover back on. Replace the flash into the metal cage and screw it back in. Finally, put the metal outer casing back on the camera and, before screwing it in, try to turn it on. Hopefully it will work again and you can screw everything back in. If not, your problem will require significantly more disassembly.
Posted on Apr 08, 2008
E18 error on powershot canon
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Sep 27, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Canon sd450, e18, need schematic of lens
http://www.e18error.com/
here are instyructions and a reference to the schematic at the bottom of the page.
cheers
Jul 31, 2009 | Cameras
E18 appears on the camera and the lens won't close
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
How disassemble?
Open battery covering and (A/V/USB) covering - find a hidden screws there.
Aug 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Help
Place a thick bath towel (triple folded) on the table edge. with the camera off, hold it in your hand and tap the bottom of the camera with medium low force to the above mentioned table edge. Try turn it on to check if it's back to normal. You may need to tap it more then one time, if it doesn't work, with stronger impact force. Just be sensible, not too hard though.
In case you have doubt with this trick to fix, try google 'Canon E18' to find related problem being fixed by others with this method.
Jul 21, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
Hello there,
Jun 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Screen is showing E18
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Aug 10, 2007 | Canon PowerShot A520 Digital Camera
E18
E18 indicates a lens or "optical unit" problem. In other words your zoom lens won't function correctly. Canon will be more than willing to look after you.
Mar 29, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
