Brother tn350 jamming printer
Brother tn350 was put in to printer & printer keeps on jamming
    Sergeant:
  • 361 Answers
Mitech, this shouldn't be a toner issue, you either didn't put the drum properly back in or the paper setup is not right. The toner has no connection with the actual paper. Take everything out, disassemble it, assemble it and put it back in properly until you hear a click.
Affordable Brother TN350 Toner Cartridge
Posted on Jul 01, 2018
SOURCE:
  • 166 Answers
SOURCE: saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Posted on Feb 12, 2009
alfi819
  • 65 Answers
SOURCE: ''Unable to Print'' using a compatible Bro TN350 toner
Get a toner cartrige from Brother here
Posted on Mar 27, 2009
  • 214 Answers
SOURCE: brother mfc-420cn printer envelope jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it
Posted on May 14, 2009
  • 59 Answers
SOURCE: my brother mfc-230c keeps saying
this is an error that could get stuck in the memory, try removing the paper tray then unplugging and replugging the printer then when it's warmed up replace the tray.
if problem persists you may have a broken sensor
Posted on Mar 27, 2010
  • 67 Answers
SOURCE: I TOOK APART A BROTHER MFC-3240C PRINTER AND
well have you cleaned the head manually or by using the software thru the pc. if you have done so by hand it may cause aproblem try cleaning using the software and see id that helps.
Posted on Oct 03, 2010
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Replacement toner cartridge not accepted
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 11, 2012 | Brother Toner Cartridge Tn350 for MFC7420...
I TOOK APART A BROTHER MFC-3240C PRINTER AND CLEANED THE HEAD NOW IT KEEPS SAYING PAPER JAM PUT THERE IS NO JAM.WHERE IS THE PAPER JAM SENSOR LOCATED AT
Oct 03, 2010 | Brother MFC-3240C All-In-One InkJet...
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
Need instructions on how to fit toner
if you are refilling the cartridge for the tn350 or the tn2000 - its very easy. Remove the cap from one side - empty then refill. The opposite end has a reset gear that you need to rest. if you have the starter cartridge you will need to buy the gear...
visit these guy and they will sort you out
http://www.tonerangel.us/Brother_TN350_Toner_Refill_Kit-details.aspx
Dec 19, 2008 | Brother HL-2030 Laser Printer
Brother TN350 - Toner Problem
The toner is n/g. replace it if it leaks.Lawrence
Sep 25, 2007 | Office Equipment & Supplies
Open Questions:
75 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
