Question about Car Audio & Video
Seat Belt Chime
Is there a way to disable the seat belt chime?
  • itsdon458 Apr 02, 2008
    05 Ford Sport Trac
  • 323 Answers
Belt Minder Deactivating/Activating
Preparation
1. Before deactivating/activating the belt minder, set the parking brake.
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
1. Turn the ignition switch to the RUN position. (Do not start the engine.)
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete. Seat Belt Chime - user_offline.gif
Posted on Apr 03, 2008
How to fix or disable passenger seat belt chime? It sometimes goes off for no reason.
There is a switch in the seat that operates when someone is sitting on it. This will operate the seat belt warning if someone sits on it and does not do up their seat belt. It appears that this switch is intermittently faulty. If you remove the seat (usually only 4 bolts) you should find the wires to the switch and can either bypass it or replace it.
Feb 25, 2016 | Seat Cars & Trucks
How do you disable the seat belt chime
In the old days, before it became compulsory to wear seat belts, people would simply fit the seat belt into the catch and then sit on them.
To disable the chime, it would need to be located and then disconnected or alternatively be fooled into silence by by-passing the switches.
It would probably be more satisfactory to wear the belts.
Aug 22, 2015 | Seat Cars & Trucks
How do i turn off the annoying seat belt chime?
It is chiming with the seat belt in operation then have it checked out. I you do not wish to wear the seat belt just do it up and sit on it Why anybody would want to turn of a safety alarm is a bit beyond comprehension.
Aug 16, 2014 | 2000 Pontiac Grand Am GT
Faulty seat belt alarm
YOU CAN' DISABLE THE ALARM.IS PART OF SRS SYSTEM.BUY FROM YOU LOCAL DEALER BELT BUKAL ONLY AND REPLACE.IS EASY AND LOW COST.
Mar 28, 2014 | Hyundai Motor 2004 Sonata
Disable passenger seatbelt chime
Hi Candy, I'm glad to help!
Candy, I'm not sure why you want to disable the pass seat belt chime, maybe its going off even with no one in the seat. BUT, the only way to stop it would be to plug the seat belt into the buckle. Hope this helps and have an awesome day Candy
May 13, 2013 | 2006 GMC Envoy
2005 jaguar type-s. How can i disable the belt minder. The seatbelt alrm is making me crazy
To enable or disable the seat belt warning chime on your 2005 Jaguar Type S
1. Ensure the front passenger seat is unoccupied.
NOTE:
Steps two to five must be completed within 60 seconds.
2. Turn the ignition to the RUN position (do not start the engine).
3. Buckle the driver safety belt buckle and wait until the seat belt warning lamp extinguishes.
4. Unbuckle the driver safety belt buckle and wait until the seat belt warning lamp illuminates.
5. Repeat Steps three and four a further eight times.
6. When the driver safety belt buckle is unbuckled for the ninth time a single chime will be heard. The single chime is acknowledgement that the beltminder feature has been disabled.
The beltminder feature will be disabled until the above process (Steps one to six) are repeated. Upon repeating the process the beltminder feature will be reactivated
Apr 25, 2010 | Jaguar S-Type Cars & Trucks
Disabling seat belt chime in a 2007 Silverado
Unfortunately if you take this to a shop they can get into alot of trouble doing this for you. Some are controlled by the body control module and others are just simple circuits. Look at you seat belt female end and look for a harness that goes to it. If it's just 2 wires connect those two wires together to trick the system! You should always wear your seatbelt by the way.
Sep 03, 2009 | Chevrolet Silverado 1500 Cars & Trucks
HOW DO YOU DISABLE THE SEAT BELT CHIME ON A 1997 MERCUTY SABLE WA
Q: Are you wearing your seat belt? Yes? No?
A: No.
Solution: Put on your seat belt!!!!!! Save a life!!!
A: Yes.
Soultion: There has to be a fuse either under the dash or under the hood that controlls the chime.
There is a switch in the seatbelt connecter that controlls the chime. It has either failed or the wireing that carried the signal to shut the chime off has been damaged.
Apr 21, 2009 | 1997 Mercury Sable
Car Audio & Video Logo
389 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
