Faulty water level switch
I have a whirlpool stylemaster that won't shut off the water level and start the wash cycle. It will overflow if I don't manually turn it off. Is this problem always a faulty switch? I checked and the little hose going to the switch is on tight.
What's up with it?
ronnelini
  • 5,911 Answers
Some of the pressure switches have adjustments on them, some don't. The switch also has electrical connectors that can oxidize (corrode) and not make good contact. You can check the electrical connection to make sure you don't have a loose or corroded plug. The air hose could also have an air leak somewhere, causing the air to escape as the tub fills. This will cause low or no pressure to shut the switch off. Inspect the hose from the switch all the way to where it connects to the tub. Test pull on the hose to see if it is nice and snug on either end. Usually if it is loose on the end connected to the tub, it will leak slightly. If you don't find anything wrong with the air hose, the last choice is the pressure switch. They don't cost that much. If you wish to replace it, post back with your model number and I can give you a part number and instructions on how to replace it.
Posted on Apr 02, 2008
  • Les Marsden
    Les Marsden Dec 18, 2013
    Yes - it's the pressure switch that I need, but they're no longer available for this machine. PART # AP2905511 - any alternatives for this part?
Whirlpool stylemaster 4217141 water won't stop filling the machine and it wont start agitating
drain machine and check the water level pressure switch air pipe
that's connected to it ,it's posably blocked stopping the switch from operating. safety disconnect from mains electrical supply before removing any covers.
Nov 13, 2016 | Whirlpool Washing Machines
Whirlpool deluxe WFW9150ww01
Replace the analog level pressure switch, it sounds like it is bad, and the machine's overflow switch is the only thing stopping the fill from flooding your house... Whirlpool Washing Machine Pressure Switch WPW10239066
Jun 04, 2013 | Washing Machines
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
My maytag washer is overflowing and won't go into
Hello there and welcome to fixya
This is a fairly common problems on these and other machines
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please feel; free to post me back any comments on repair help or testing and removal ian installation if needed ill be glad to help you ok
Best regards Mike
Apr 09, 2012 | Maytag Washing Machines
Set dial and water overflows, doesn't stop sending water in tub, No spin cycle
The water level sensor is faulty and so it does not switch even with water level coming to the set level. Unless the water level switch is triggered the water inflow will not stop because the inlet valve will not cut off.Remove the water level sensor and check if the diaphragm is working , if not it must be replaced.
Mar 13, 2012 | Washing Machines
The washer will not stop filling up with water and start the wash cycle
If it only fills when switched on then the control board has a fault on it, the part which switches the inlet valve on is faulty.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 05, 2011 | Washing Machines
Water runs continually during all wash cycles
Check the water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube. When it reaches a certain level, it activates the switch to shut off the water and signals the timer to start appopriate cycle. Make sure the plastic tube is not damaged or obstructed. The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Sep 02, 2009 | Whirlpool LSR6332K Top Load Washer
The washer overflows
Aug 19, 2009 | Washing Machines
Fills up with water and wont stop
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Oct 16, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
