Question about Panasonic DX-2000 Plain Paper Laser Fax
DX 2000 Panafax
It has a security password on it that is keeping me from changing the configuration. How do I remove this setting so I can reconfigure the DX 2000?
Thanks
    Sergeant:
  • 284 Answers
The only way to clear the password is to do a shipment set.
Posted on Oct 15, 2008
SOURCE:
I want to reset my stc internet connection password
Hello elmer_mid347,
These are instructions:
To Reset and Restore the "Router Password."
The first thing you want to do is to "Reset" the Router's configurations.
To factory defaults settings.
First, hold the reset button on the router for 30 seconds.
Once your router resets, you will need to Login and reconfigure it again.
To reconfigure your "Router!
"Connect the Computer to one of the Ethernet Ports.
Next, type in your Web Browser: http://192.168.1.1
You will be asks you to enter: "Username and Password, to log-in, to your router."
You can also, use the Router's ("Default Password"), which is; admin.
"You should be able to reconfigure the "Router."
Next, go to the Management (Tab) to change the Administrator's password.
Next, you will need setup the Security for the Router.
"Select to ("Enable") the "Security Codes," example: WEP..."
"This should change, and 'reset' the password!
If you need help with anything else?
Write a 'comment'; I'll be here to assist you!
"Best Regards"
Aug 05, 2011 | Computers & Internet
My local public network is asking for a security key number
Probably as is open and with no security some one change the wireless setting adding security to the router, Reset the router to factory settings and add a password to reconfigure the router not to the wireless connections, in that way people can still use the public internet but cant configure the router because dont have the password.
Mar 12, 2011 | Computers & Internet
Change my router password
Click around once you're in the settings. There should be a setup tab with the password change somewhere.
Mar 12, 2011 | Linksys WRT160N Wireless Router
I need to secure the network from my router ....how do i do this?
  • If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds
    Once your router is hard reset, you will need to login and reconfigure it again.
  • To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
    LinkSys Default Password
    On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
    Once you are past the login screen, you are able to reconfigure the LinkSys router.
    You want to go to the management tab and change the administrator password to something else to keep others from accessing your router.
  • After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Oct 11, 2010 | Linksys Wireless-G Broadband Router
    Lost my password and cannot connect new netbook
    hi
    To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  • Step 2reset-password-linksys-router-1.2-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a02/2p/6m/reset-password-linksys-router-1.2-800X800.jpg'); }); Once your router is hard reset, you will need to login and reconfigure it again.
  • Step 3 After changing the administrator password then you will need to enable WEP or WAP security so your nosy neighbors aren't tapping into your wireless network. I am picking up 4 networks with my pc antenna.
  • Jul 21, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    Ip address wrong, showing 192.168.254.1
    Solution Overview
    This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
    Printer response to security settings changes
    The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
    • -A change to the Service Set Identifier (SSID) or network name.
    • -A change to the security type (none, WEP, WPA, or WPA2 personal).
    • -A change to the security network key/passphrase.
    • -A hard reset of the router followed by entry of security values that are different from the original values.
    • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
    In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
    Solution: Change the printer settings first
    Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
    Procedure: How to change security settings via the embedded web server
    If you change your AP security settings frequently, this procedure is for you.
    1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
    2. Click on Configuration.
    3. Click on Wireless.
    4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
    5. Click Submit.
    Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
    Got new laptop. broadband working but can't connect to wireless connection. how do i reconfigure it?
    To set-up and secure the wireless router from unauthorized access, follow these steps :-
    1. Connect the wireless router to your computer with a LAN cable.
    2. Start your browser and enter the router's configuration URL IP address.
    3. Enter the router setup, login and password
    4. Change the admin password
    5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
    6. Setup encryption key the strongest is WPA2 (if not then WPA).
    7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
    8. Record the settings you have made and keep it in a safe place and Save the settings.
    9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
    10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
    Nov 06, 2009 | D-Link AirPlus DI-524 Wireless Router
    Panafax DX2000(au)opt
    HAVE YOU TRIED A DIFFERENT CARTRIDGE
    IF NOT SC PWB
    Jun 13, 2008 | Panasonic DX-2000 Plain Paper Laser Fax
    Panafax DX 2000
    the only way to clear the password is to do a shipment set.
    Apr 02, 2008 | Panasonic DX-2000 Plain Paper Laser Fax
    Panasonic DX-2000 Plain Paper Laser Fax Logo
    77 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Shannon Murphy
    Level 1 Expert
    jasbo
    jasbo
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
