Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Flash won't fire
I have a Nikon D40. Recently I noticed when I took a picture, the flash would pop up but not fire. Any suggestions
  • magooey Apr 16, 2008
    i have the same problem it will pop up but when i press the shutter it makes this clicking sound like the camera is trying to pop the flash up again plese help!
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
Here's a <a rel='nofollow' href='http://photo.net/bboard/uploaded-file?bboard_upload_id=42254384'>photo of the sensor in a D70</a>. The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Posted on Apr 27, 2008
SOURCE:
My Nikon D40's Flash wont pop up, and when it shoots it just smokes? I tried following a video but still nothing :/
maybe the flash is stuck, try pulling it out. sure if it is smokes coz flash delivers heat when it's fire.
Sep 18, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 flash won't fire
Goodluck..
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Feb 27, 2009 | Nikon D40 Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
D40x flash not working
I have also had the problem of flash not working on my Nikon D40. I found out the problem and I also made a quick video to help those who are having this problem. Here's the link to the video: Hope this helps !
Nikon D40 Flash Fix
Nov 03, 2007 | Nikon D40x Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
207 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
