Question about Kenmore 98702 Stacked Washer/Dryer
Water will not drain on the spin cycle
I have a Kenmore stackable washer and dryer model number 417.72990 and i made a mistake and washed a rug a couple of days ago.....a lot of material came off of the rug....initially i removed the rug but the tub was still full of water and material from the rug....i fished all of the water and material from the tub and attempted to continue washing......now no water drains at all......i am a pretty handy female .....an electrician by trade so i know that i can fix this myself with your help. Just tell me what to do please so that i don't have to pay for a service call.....thank you in advance for all of your help
  • mmleon Apr 03, 2008
    Same issues. I've asked 3 different people and have gotten 3 different answers:
    1. electriccal
    2. belt issue
    3. "sump'n peer's ta be stuck all down up n thar."
    I'd appreciate any help offered.
    President:
  • Kenmore Master
  • 2,651 Answers
Sump'n peer's ta be stuck all down up n thar."--- thers an answer id go with..
backing to the rug ir perhaps the tassle ends have problaby clooged the pump assy preventing water from draining, i couldn't look up schematic firyou , themodel number was not found at sears website, but yea, defff sounds like there "sump'n peer's ta be stuck all down" the pump will hav a ghose leading to it, yuou should be able to flsh out the debris cant see needing to replace the pump
Posted on Apr 04, 2008
SOURCE:
Stackable kenmore washer dryer
could be a clogged pump or drain hose causing the water to spin over the top
Jan 15, 2013 | Washing Machines
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
144 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
