Question about Pioneer DEH-P6400 CD Player
Pioneer 6400 car stereo
Ive fitted a pioneer 6400 in car stereo in my car and when i wire the speakers in they all work bar 1 which makes a horrible noise and when i disconnect that 1 they all go off any solutions .ps the speakers worked fine when i had a sony in it.
  • 3 Answers
Yeah your best bet is to double check the wiring and it you still cant figure it out..the easiest fix is run new wire to each speaker that will insure that nothing is messed up in the wire harness of the vehicle
Posted on Feb 12, 2009
  • 113 Answers
Check to see if any of the other speaker wires are going to ground -it sounds like one or more of them are
Posted on Apr 02, 2008
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I have a pioneer avh-6500dvd when I wire it up it turns on but nothing works also it makes a funny noise from the speakers and I can't enter a cd or when I press the eject button the power turns off iam...
Please check that your stereo unit works on a different car first.Sounds like the speakers are shorting out. This may be a defective unit.
Did the old stereo work ok?
Roger
Apr 07, 2014 | Car Audio & Video
Crackling and scratching
Your speaker may be blown take out the speaker that is hooked up and attach another one a house speaker would even work, and i bet your speakers are blow if not check the wires and make sure you have them connected properly if not check the wires going to the harness and to the speaker and if not i think the radio is fried you can also take a long speaker wire take radio out the dash and run it to the speaker if it does still the radio is fried take it back before 90 days is up!
May 29, 2013 | Pioneer Car Audio & Video
How do i install a pioneer radio without the instructions
Aftermarket radios have a standard wiring color set. Tell me the radio model and car year/model and I can send you the exact connection scheme.
Dec 01, 2010 | Pioneer Car Audio & Video
I got a ford aspire and a pioneer radio how do i hook it up
It is best to buy a connector pigtail for Ford, but you can wire directly using the below color code for the factory wiring. use the color code from the pioneer to match to the factory wires. If you have more questions, please reply.
1994 Ford Aspire Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Light N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Brown/Black
Left Front Speaker Negative Wire (-): Green/Red
Right Front Speaker Positive Wire (+): Green/Orange
Right Front Speaker Negative Wire (-): Blue/Orange
Car Audio Rear Speakers Size: 5 1/4?
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Brown/Red
Sep 29, 2010 | 1994 Ford Aspire
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
Jun 02, 2009 | Pioneer DEH-P4100
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer car stereo instalation
if they are all positive speaker wires then each speaker will get a positive and the other speaker wire goes to the ground of the ground wire
Oct 12, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Pioneer system Query
usually red, black, yellow for the power.. the rest are for the accessories.. ie. speaker, optional amplifier power on trigger.
black goes to the ground or chassis.
red goes to ignition (so the head unit willl only power on when the ignition is in ACC or accessory)
yellow goes directly to the battery but fused.
Apr 10, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P6400 CD Player Logo
525 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
