I can not retrieve my information off my jump drive
    Sergeant:
  • 318 Answers
Jump drives can go bad. If it is not readable in more than one computer, the information on it may be toast.
Posted on Apr 02, 2008
SOURCE:
Can I retrieve data from a non-working hard drive?
There are people who can retrieve data from dead hard drives but it can be costly so get quotes first-- look in the phone book
other than that the data is long gone
Feb 10, 2016 | Power Computers & Internet
How do I retrieve my information from a Clickfree backup harddrive that is no longer working?
the clickfree hard drive is the same as any other hard drive and when it fails it has lost everything
there are computer shops that may be able to retrieve the data on the disc but you will have to ring around to find one
try places on the net
Jan 09, 2016 | ClickFree Computers & Internet
When using a jumper wire to retrieve ABS trouble codes on a 2002 Trooper 4 wheel drive how is the DLC numbered? I mean which pins do I jump? And when I do jump, Will the ABS light flash te codes....
ok, there are 16 pins in the DLC you want to jump #4 and #12 as you look at the connector from left to right top row is 1-8 bottom row from left to right 9-16, both rows the 4th pin jump them together. then count the flashes all codes are 2 diget ( example flash-flash pause flash-flash = code 22 )
Feb 17, 2011 | 2002 Isuzu Trooper
Hard disk not detected - Need to retrieve data
If it is your system drive (C:)
You can remove it and try connect to another computer (internal or in an external caddy).
Usually you can get the information you need like this.
Jul 23, 2010 | Samsung (SP0411N) 40 GB Hard Drive
I would like to retrieve information off my old hitachi model dk23ea-40. What so I purchase to pull the information from my drive to my lap top
I assume this is a PATA (IDE) drive but, even if it is SATA, you can buy quite cheaply a docking station or adapter which enables you to link the drive to a USB port.
This way you can retrieve the data or leave it there and use the drive as an external backup.
Hope this helps,
CJ
Jul 01, 2010 | Computers & Internet
Retrieve information from a flash drive
I don't know how to recover the files from a broken flash drive. I DO know how to fix one (which would resolve your problem), but that's not really something I can explain (unless you're experienced in computer and component construction).
Your best option would be to check your local listings for companies that can repair your device.
OR, you can look for a data recovery service in your area.
Finally, I do know a web site that can retrieve those files for you:
http://www.ontrackdatarecovery.com/
Mar 19, 2010 | Toshiba Computers & Internet
How to retrieve backup to a reformatted hard drive
The Maxtor will have come with backup software. You need to install this software on your PC and search out the restore mode.
Apr 16, 2008 | Maxtor OneTouch II external hard drive...
Retrieving information on a reformatted USB drive
Unfortunately when its been formatted all the data stored gets wiped off.
You could try searching on the net for data retrieval programs and see if any of them can help you. Something like this
Good Luck
Mar 23, 2008 | Electronics - Others
Lexar Jump drive sport
I can e-mail you recovery software to see if you can access your [email protected]
Mar 05, 2008 | Computers & Internet
Open Questions:
aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...aVg TeCh SuPpoRT pHoNe {*@'#,{1+888'4995520-}...
Oct 17, 2019 | Computers & Internet
avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7avg support PhOnE nUmBeR @$ 1.{888.*499.*5520}*.24*7
Oct 17, 2019 | AVG Computers & Internet
Computers & Internet Logo
22 people viewed this question
Ekse
Alun Cox
