Question about Garmin nuvi 350 GPS Receiver
Freezing - won't clear screen even after disconnect
Everything worked until I was submitting a new address and wouldn't go to the numbers screen.
Escaped out and went to settings and is frozen on the 1st screen for settings. (system, display, navigation, time, etc.
    Scholar:
  • 174 Answers
What model gps is it?
Posted on Jun 12, 2008
How to change Blackberry ID?
If you would like to keep your existing BlackBerry ID account and simply change the email address that is associated with the account, use the steps for your specific device below.
Note: Your new username must not already be associated to another BlackBerry ID.
If you need further support, you can get BlackBerry ID support here.
On the BlackBerry 10 smartphone:
  1. Swipe down from the top of the home screen and tap Settings.
  2. Tap BlackBerry ID.
  3. Tap the edit Edit button.
  4. Clear the BlackBerry ID Username field and enter the email address to use as your BlackBerry ID Username.
  5. On all-touch devices, press and hold the space bar to hide the keyboard.
  6. Tap the Submit button.
  7. Read the confirmation message, and tap Continue.
  8. Enter your BlackBerry ID password and tap OK to complete the change.
  9. A message is displayed to confirm the change was successful. Tap OK to return to the BlackBerry ID settings screen.
On the BlackBerry smartphone running BlackBerry 7 to 7.1:
  1. From the home screen, select Options > Device > BlackBerry ID.
  2. Clear the Username field and enter the email address to use as your BlackBerry ID Username.
  3. Press the Menu key and select Save.
  4. Enter your BlackBerry ID password and select OK to complete the change.
  5. A message is displayed to confirm the change was successful.
On the BlackBerry PlayBook tablet:
  1. Swipe down from the top bezel or tap the Settings icon.
  3. Tap the BlackBerry ID Information pencil icon.
  5. Tap Submit.
  6. Enter your BlackBerry ID password when prompted and tap OK.
  7. A message is displayed to confirm the change was successful.
On the Android device, iPhone, iPad, iPod touch, or Windows Phone:
  1. Open BBM.
  2. Tap the More button (3 dots).
  3. Tap Settings. If using a Windows Phone, also tap General.
  4. Tap the BlackBerry ID email address.
  5. Enter the BlackBerry ID Password and tap Sign In.
  6. Tap Edit Account Information.
  7. Clear the BlackBerry ID Username field and enter the email address to use as your BlackBerry ID Username.
  8. Tap Save.
  9. Scroll to the bottom of the Account Information screen and tap the Done button.
  10. Tap the Back button to exit Settings.
From a web browser on any device or computer:
  1. Visit http://www.blackberry.com/blackberryid.
  2. Under Already have a BlackBerry ID?, click Sign in.
  3. Enter your current username and password, and click Sign In.
  4. Next to Details, click Edit.
  5. Clear the Username field and enter the email address to use as your BlackBerry ID Username, then click Save. A confirmation email is sent to the email address.
  6. Open the email from donotreply@blackberry.com with Subject: Confirm your BlackBerry® ID email address. In the message body, click confirm your email address.
  7. On the Confirm your BlackBerry ID screen, enter your BlackBerry ID password and click Submit.
  8. A message is displayed to confirm the change was successful.
Apr 09, 2015 | Blackberry Cell Phones
Tip
Have a problem connecting a new computer to your network? This is kinda easy to...
Have a problem connecting a new computer to your network? This is kinda easy to do, first find a computer thats already connected to the network, then go to the settings of the network and write down all the information about the network like the wep key, dns server, and even the ip address. Then go the the new computer and go to the settings and fill in everything you wrote down, UNTIL the ip address, this is where it get a little confusing. write down the copied ip address but change the very last number to one number higher that it for example: connected computer ip address: 192.180.1.900* Then here is the ip address you will place on the new computer: 192.180.1.901* then your computer should connect.*=made up number do not use it
on Feb 09, 2010 | Computers & Internet
Vespa P150X Piaggio won't start
i think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new onevespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-2.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Jan 03, 2013 | Peg Perego Vespa Scooter
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
"dowload standby" on canon ir
Basically, this is the mode to reinstall the system software. If powering down didn't clear the message then you will have to do an " All Clear. " Now this will clear out any kind of information you have stored like FAX numbers, Nmaes, etc. Press additioanl function key, then 2, then 8, then additioanl function key again. This gets you into service mode. Press the left arrow until you see #CLEAR, then OK. Press the left arrow again until you see ALL, then press OK. This is what I call a hard copier reset. This should put everything back to factory presets and you will have to put everything you had it before. Now I can't remember if it will need to be powered down after this but it wouldn't hurt. Good Luck.
Sep 17, 2011 | Canon iR 2016i Black and White Copier
I went out to move my 2005 cavalier and when I shifted from reverse to drive, it slipped right thru everything and wouldn't catch. It wouldn't even catch in park. I pulled the parking break and...
I don't know beans about automatice transmissions and the average person can only check the fluid levels and take it to a transmission shop if it is more serious.
As far as the engine goes, you need to localize the problem because with the other indications it might not be the normal stuff. So, what I would recommend is that you take the serpentine belt off and try to turn the crank with a large wrench (CW only) with the car in neutral. If you can turn it, then it is probably not your engine freezing up. If it won't turn then the transmission is probably not disengaging from the flywheel - maybe the torque converter.
If it does turn over, then you can put the belt back on and try to jump start the car with another vehicle or the boost function on a battery charger. It it starts then you know to look at the charging system - battery, alternator. If it doesn't start then the starter or the starter reley.
Sep 06, 2011 | Chevrolet Cavalier Cars & Trucks
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
The mower started. then just quit like ran out of gas. we blew thru the gas line going into the tank. then cleaned out filter. it won't start. at first it wouldn't even drain any gas out but we...
If the gas won't even drain from the tank, try removing the gas cap. It has vent holes and if this is plugged, the vacuum won't let the gas drain. If that is the case, clear the holes.
Gary
May 19, 2011 | Cub Cadet Street Sign- tractor lawn riding...
The router keeps disconnection and reconnection. How do i fix it so it stays connected all the time.
Hi i got your issue .......
Please try with the following steps ......
Step 1 : Connect modem -Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3: Towards the left corner below INTERNET WAN click on "connection type"
Step 4: Select the connection type as dynamic and hit next
Step 5: Click on change wan mac address -and then click on clone computers mac address.....
Step 6: Your status will change to connected
Step 7: Now you minimize that page and open a new browser page
Step 8: On the address bar clear everything and type www.belkin.com/support
Step 9: On this page click on the routers picture and on select 1- choose basic and on select 2-f7d1301 and select -3- v1000
Step 10: The n click on the blue arrow -and you will find the firmware download and save it on the desktop
Step 11: Open the screen which you minimised earlier and towards the left below utilities click on update firmware and update the saved file
Step 12: On the left under wireless click wi - fi protected setup
Step13 : Leave the password blank and click on submit
Step 14: Disable it and Click on apply changes
Step 15: On the left under wireless click Security
Step 16 : Enable 64 Bit WEP
Step 17: Type a 10 digit number on the key 1 ( 2 in each box )
Step18 : Click apply changes
Step 19: on the left under wireless click channel and SSID
Step 20 :Change the Wireless channel to 6
Step 21 : Change the SSID to a different name ( no Spaces )
Step 22: Click apply changes
Step 23: Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Thanks.....
With regards ......
Priya ,,,,,
Oct 22, 2010 | Belkin (F5D5231-4) Router
Garmin nuvi 350 GPS Receiver Logo
47 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
