Question about Mitsubishi VS-60603 60" Rear Projection Television
Sound but no picture
I just bought my tv from someone and got it home and it played for two hours perfectly. then the screen started blacking out and then sound but no picture. so i took the back off and the projectors still had light but would not project onto the screen. what do you suggest i do?
  • 58 Answers
It may be fluid from the picture tubes. They have a silicon based fluid inside the lens housing that helps keep them cool, unfortunantly the fluid in this model leaks. The fluid is corrosive but not conductive, meaning that it can sit on the board long enough to eat through the board but not short it out. There is a 1" square ic on the main board (large green board on the left) usually if there is fluid damage it will be there and you will know it by:
1. green residue all over or around chip
2. clear fluid on the board.
This is a very common problem and is almost always catistropic. Meaning that the tv is not repairable. I hope you don't have this problem but chances are that you do or will in the near future with this model. This is just a guide as to where the fluid may be on the board, but it may be anywhere. Hope this helps.
Posted on Apr 02, 2008
SOURCE:
Screen totally black
Try to play around with the cables as you might have not inserted all the cable properly .
Feb 13, 2014 | Televison & Video
Lord of the Rings: Conquest for PC error
Check your screen resolution. The optimum settings should be listed in your guide book.
Also, check the graphics settings required for the game compaired to the graphics card in your computer; you may need to upgrade.
Good luck and please rate my solution accordingly.
V/r,
Don
Jan 28, 2010 | Electronic Arts The Lord of the Rings...
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
Black Rectangle Box appears shortly after turning on TV
That is the PIP (picture in picture) setting, on the TV's remote control. locate the button marked PIP and press the button, it should clear the little box.
Apr 04, 2017 | TruTech PVS31170S1W 17 in. LCD Television
JVC T. V. Model # 26505
I can only suggest you check your audio feeds from your VCR to your TV or to your home theater system tuner(if you have one)
Feb 06, 2008 | JVC AV-27230 27" TV
Dark Picture
Symptom: NO PICTURE
Cause: DEFECTIVE 3D/YC COMB FILTER
Symptom: DARK PICTURE
Cause: DEFECTIVE C724
Jan 16, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Black Picture
The picture coming on then going off to a totally black screen is a sign of the high voltage generator being marginal in its performance.
The repair may be simple and inexpensive; or something more sinister. The technician will have to tell you.
Let me know the outcome. I am very interested in this rather strange case.
Jan 14, 2008 | Philips 50P8341 50" Rear Projection...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
