Question about Grilling
Thane Q Grill
The burners won't stay lit. Igniter works and under the light dome there is a valve with a rubber button on top. I can depress this button and get gas to the burners, however when I let go of the button, the gas stops and burners go out.
  • 1 more comment
  • lloydjolson May 22, 2008
    My Jenn air back rotisserie burner won't stay lit. it starts without an issue but goes out once everything is hot. What is the problem
    ? The thermal couple seams to work correctly but once everything is hot the back infra-red burner goes out.
  • rdosser May 15, 2009
    Whatever was over that pressure button has broken off, and i have to hold that thing down in order to keep it lit. Very, very frustrating.
  • Mike Jun 08, 2013
    brought one about 10 years ago off thane direct infomercial, used it 3 times, , on the third time i tried to use it no gas came, out, and I unscrewed the plastic dome to find the red button with the spring broke off by it self, i found that if i used a toothpick in the place were the red biutton was the gas would come out of the canister, so seems likle it was bad common design flaw, no wonder the stopped making it, and dont provide any after sales support
I just read this post as I was surfing for the Q-Grill - which they don't make anymore according to their website, and I looked everywhere - Amazon, Ebay, etc. I'm looking to buy a second Q-Grill; the "Turbo" actually. My first one still works great! Anyways, I know it's almost a year for a response but if you're still having the issue (or if anyone is currently having this issue), that you stated regarding the "red" button under the dome light - I had the same problem after the first year of using my Q-Grill. The red cap (or button as you call it) cracked and the spring inside was popping through the crack. The red cap kept the pressure on the spring which was pressing the gas valve button to let the propane gas flow through the pipes. Its almost like a safety mechanism. Without the red cap on the spring, the gas valve button wouldn't be depressed, and no gas flow - Cold burgers! Yuck!....Any how, my solution was to place a thin, flat piece of wood like a very thin plywood; 1-1/2"(inch) by 1-1/2"(inch) and 1/8 to 1/4 inch thick over the cracked red cap, then I screwed down the dome light housing on top of the wood piece which rests on top of the red cap. The dome light housing now applies downward pressure to the wood piece, which applies pressure to the cracked red cap and the spring inside which is activating the gas valve button for gas flow. An alternate solution to using a piece of wood is using a piece of paper and folding it to make a small square (you may have to cut the piece of paper). And fold the piece of paper enough times to make it thick enough for the dome light housing to apply pressure once you screw it down.....I hope this helps you out.
Posted on Mar 25, 2009
I had this problem also but found a solution! Make sure you clean out the burners really good if you have the old cast iron burners. Rust, spiders etc get up in the front air tube part of the burner. Knock the burner on something and watch all the old rust come out of it. Secondly, what I found cured the problem was making sure the air inlets on the back of the lid are not clogged with grease etc. Clean these out, its most important because it creates an air draft that provides oxygen and a pull draft for the flames coming out of the burners. These 2 soultions should work and if not you may need to get the new stainless burners and new valves. Give it a try, it worked like a charm for me!
Doug Morgan Jr.
Posted on May 02, 2008
Hi i have the same fault with my Q grill use it once about 2 years ago went to test it before we go away but it don't work. same thing with depressing the button?. it's not actually a button, it's a gas valve which had a red cap on with a spring inside. if you can get a new valve then we're sorted.
Posted on May 25, 2008
  • 32 Answers
Try contacting the company with problem is best bet.
Posted on Apr 06, 2008
Igniter glows but why doesn't burner light?
Igniter could still be faulty(not hot enough) or burner control valve
faulty. press the helpful button and check link videos below
Gas Stove Top Burners Not Lighting Not Working
Gas Stove Ignitor and Burner Not Lighting
Daddy Chores Gas range won ignite How to fix it
Jan 22, 2016 | Kitchen Ranges
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from
Jan 04, 2016 | Ovens
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
How do i relight my standing wall heater light, where is it?
There should be a removable panel on the bottom front. Remove this panel and you should see gas valve with two lines going into combustion chamber. The larger of the two will be for burner and the smaller to the pilot light. There may be lighting instructions on the inside of panel,or on front of burner compartment. If not look at gas valve and see if you can see where it is marked off pilot and on. Turn thermostat to lowest setting and gas valve to pilot ,locate pilot light and hold match to it while you depress pilot button . Pilot should light. If it does hold button depressed for 1 to 2 mins. Release pilot button and if pilot stays lit turn valve to on. Turn thermostat up to desired setting and see if burner comes on. If it does you should be done. Put cover back on. If pilot light does not stay lit or burner won't light I Would recommend you call a service tech as there are several things that could be wrong. Hope this helps you.Thanks
Nov 12, 2010 | Montgomery Ward (223600UP) Heater
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Grilling Logo
1,331 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
