Question about Sony Cyber-Shot DSC-S40 Digital Camera
Lens won't stay out and beeps saying turn off and on
The camera, when turned on, the lens goes in and out and then beeps saying turn power off an on. When turned off, the lens won't even go in all the way and shutter doesn't close. Please advise.
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
SOURCE:
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
When I turn the camera on, the lens come in and
its a problem of your lens guide pin. thats damaged & you face that problem. Just replaced that. Thanks
Mar 27, 2010 | Cameras
Lens goes in and out, stays out when off and says
I'm sorry that the lens of the camera is not retracting. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under Main settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 26, 2009 | Sony Cameras
When trying to power up hear 3 beeps and camera turns off.
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
May 09, 2009 | Cameras
My camera says "Turn the power off and on again"
there is a problem with the lens already and it might need replacement. chances are the price of a lens is almost equivalent to a new camera.. just buy a new one.
Aug 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Problem with lens
throw it on the floor again
IT WORKS!!!!! YYYYEEEEEEEEEEAAAAAAAAAAA
Jul 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
CAMERS TURNS ON LENS OUT THEN BACK IN... 3 STEADY CLICKING SOUNDS
well i´m the bad news guy, it could be two things, or u droped the camera and the zoom lens is out of the place and the sensors arent working properly or it´s just the sensors that are no working, the only way is to send to a repair centre normally they just replace all the lens. All the beeps it´s just to say that the lens is lost.... can´t locate it self.
Feb 04, 2007 | Canon PowerShot A95 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
48 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
