Question about Samsung SGH-D900 Cellular Phone
Phone switches off when dialling a certain number
My mobile works fine 99.9% of the time. However, when i tried to dial a certain number stored in the phone, the phone just switches off.
The number does work as I've dialled it using a normal phone and i can send texts to it via the mobile. But try and ring and - the mobile switches off. It's weird. Doesn't happen with any other number!!
Advice please.
  • 24 Answers
Looks to me like maybe an update to your mobile may have gone wrong and I have a samsung 370 and nokia 5200 and my samsung freezes and turns off wen i view a picture sometimes my samsung has been damaged so that may be the problem with yours please reply... :)
Posted on Apr 02, 2008
SOURCE:
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
What does Fixed Dialling Numbers mean?
Fixed Dialing Numbers or FDN list is a SIM card based security feature which allows the phone to be "locked" so that it can only dial certain numbers, or numbers with certain prefixes.
A PIN2 code (numeric password) protects the allowed list of numbers from being changed by any person who does not know the PIN2 code.
In FDN mode, your device will restrict outgoing calls, except for the numbers stored in the FDN list.
To activate FDN mode,
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Enable FDN.
2.) Enter the PIN2 supplied with your SIM or USIM card and select OK.
3.) Select FDN list and add contacts to be used in FDN mode.
To De-activate
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Disable FDN.
Warning: PIN2 is a serious SIM-based security feature of the handset. If you are not sure of your PIN2, please do not enter random PIN2. When you access a menu requiring the PIN2, you must enter the PIN2 supplied with the SIM or USIM card. Contact your service provider/ Network for your PIN2. If the wrong PIN2 code is entered three times in a row, PIN Lock(PUK2) will be automatically activated.
Oct 31, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
Which ones are you looking for?
Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
System speed dial numbers are entered from the main or manager's phone under system program 001.
Carl
Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
How do you save numbers for one touch dialling?
Press PROG the button and dial 2 + 9 + the number and STORE.
If your outside line access code is something different, insert it instead of "9".
carl
May 20, 2009 | Panasonic KX-T7630 Corded Phone
Cannot get dial tone
try to make an incoming call to the phone in question by dialling the phone number from a mobile or whatever.if the phone does not ring then the line itself is not connected or has a wiring problem.
so if no dial tone and no incoming calls then check the line itself
Dec 20, 2008 | Lands Phones
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Samsung SGH-D900 Cellular Phone Logo
69 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
