FixYa.com
Tags:
Compaq Armada M700 PC Notebook
Boot Error/System Halter (by 2 users)
posted by LoeLLe on Apr 02, 2008
Whenever I open my laptop and after it shows the Compaq brand, it automatically get black and a Boot Error/System Halter always appears then that's it. It does not moves on to the windows. and every key that i press is invalid.
Comment by LoeLLe, posted on Apr 02, 2008
(01) What operating system is your computer running?I'm not sure of what an operating system is but I think it has Microsoft Wnindows 98, 2nd Edition
(02) Do you hear (or have you recently heard) any unusual noises coming from your laptop? There's none.
(03) Has your laptop been dropped recently? Yes, before it has been dropped, it was still running.
(04) Did any event that you can think of precipitate this issue (installing new software or operating system updates, drivers, software, etc.)? I haven't installed anything recently.
(05) What is the make and model of your laptop? (You can find this information usually on stickers on the bottom of the laptop) Compaq Armada M700
(06) Does your laptop have a CD-ROM drive? yes it does.
(07) Does your laptop have a floppy diskette drive? none.
(08) Do you have the system restore CD(s) for this laptop? I think they were all lost now.
I'll wait for your solutions. Thank you for paying attention to this problem.
Thank you,
Loelle
Comment by LoeLLe, posted on Apr 03, 2008
SERIAL NO. AM7P3650T4X6DC6458
I dont know where i can find the part number.
Thank you So Much,
LoeLLe
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 06, 2008
my computer says DRIVELOCK HDD PASSWORD...i cant use it anymore. How can I Fix It?Please help me about this problem
Clarification Request
by mvungi, posted on May 12, 2008
I have similar problem but mine originated from reseting BIOS to factory defauts. After that it does not see the hard disk. There is no place to select hardisk auto feature in rom configuration. The computer boots with CD-ROM drive. How can I access in HP notebooks/laptops the hardisk setup in bios rom configuration? Can anyone assist?
by Pterocarpous, posted on Apr 02, 2008
Hello LoeLLe
There are many issues that can cause your computer to fail to boot up (start). We'll need a bit more information in order to help you to diagnose the problem.
We will need to get more information from you as we trouble-shoot this problem with you. Please, be sure to answer each question that we present you w/ clearly. It is a serious problem, as you know, so, please, be patient as it may take a little while to get it sorted out.
Thank you,
BJ
Best Solution
Helpful (85)
Pterocarpous
Rank:Guru Guru
Rating: 92%, 111 votes
Hello LoeLLE
You're welcome, of course. That's what we're here for.
Thank you for answering each question. You're right. "Microsoft Windows 98 SE (second edition)" is the name of your operating system.
FYI: Some great resources for finding out what different computer and Internet-related terminology mean are:
http://www.wikipedia.org
http://www.whatis.com
http://www.dictionary.com
http://www.webopedia.com
http://www.urbandictionary.com
HERE is a link to some "quick specs" (specifications) for your computer. Please, look closely at the part numbers on the left to see exactly which one is yours. If you can find the serial number for your computer as well (should be on a sticker on the bottom of the laptop), that will help a great deal.
The 1st thing that is needed is to test your hard disk drive. If it has failed then it will need to be replaced b4 you can move forward w/ restoring your operating system.
For that you are going to need a CD-R disc. This disc will be used to "burn" (copy) the hard disk drive diagnostic onto.
We'll get to that in a bit. For now, please, identify your specific computer (by serial number and part number). W/ that information we can determine what hard drive is in the computer so that we can choose the appropriate hard drive diagnostic utility.
Thank you,
BJ
Comment by Pterocarpous, posted on Apr 03, 2008
You can find information and downloads for your laptop HERE on HP's website.
You can find manuals for the computer HERE.
One manual in particular is the MAINTENANCE & SERVICE GUIDE for your computer. You can find it HERE .
Follow the steps outined in section 2.5 beginning on page 2-7 of the SERVICE GUIDE.
Can you get into the Compaq Utilities as directed on page 2-7?
It is possible that you can get into the Compaq Computer Setup even if you cannot get into the Operating System (boot the computer successfully). If you're able to get into the Computer Setup, record the information shown in SYSTEM INFORMATION and post it back here.
Now, go to section 5.5 and follow the instructions there for "Preparing the Computer for Disassembly"
Next, go to section 5.7 and follow the instructions for (temporarily) removing your computer's hard drive. (This is to identify the hard drive manufacturer.)
You're fortunate. The hard drive is very easy to access on this particular laptop model. It requires only a phillips screw driver.
SOME WORDS OF CAUTION FIRST:
BEFORE you begin, disconnect the power cord and remove the laptop battery.
DO NOT touch any part of the hard drive other than its metal case or housing.
NEVER touch electronic circuitry on any computer component as a static discharge from you can seriously damage the sensitive electronic components.
If the hard drive is installed in its laptop housing bay w/ the identification sticker up (visible), then you need only record the information on the sticker then re-install the hard drive back into the laptop. (Please, post back here w/ the information you recorded.)
If the hard drive is installed component side up (electronic circuitry exposed), and you cannot see the sticker w/out removing the hard drive from the laptop bezel housing, please, post back here b4 proceeding.
Let us know how you do. Take your time and be patient with yourself. This is tedious work particularly if you are new at it.
BJ
Comment by Pterocarpous, posted on Apr 16, 2008
Hello LoeLLe
Hopefully by now, the issue w/ your laptop has been resolved.
We can't always repair your problem for you here on FixYa.com but we can, as I did for your problem, provide key information and links to resources that will enable you to pursue a diagnosis or know what steps to take next to get your computer repaired.
Since I did provide you w/ these things, would you mind taking just a moment to re-rate my solution to a "FixYa" rating? I would be most grateful if you would not mind. :)
Thank you kindly!
BJ @:)
Rating Locked! (?) LoeLLe has rated this solution as Helpful
Can you Help with these PC Laptops problems?
PC Laptops
New ASUS G50vm-x1 from Best Buy
I bought this laptop yesterday,... Answer This...
PC Laptops
Power-on Password
I trying to see were to send in... Answer This...
PC Laptops
acer aspire 4720z audio driver...
can't load the audio driver on... Answer This...
compaq armada m700 wont boot up
everytime i try to boot up my... Answer This...
compaq armada m700
how do i no what to solder and... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
