Question about Frigidaire FRS26ZSG
GE model gss side by side refrigerator
It is not cooling. The coils at the bottom freeze up, have tried defrosting them with a hairdryer. I have tried moving the switches, they click the thermosat on. But within a few minutes the coils again freeze up.
  • gegss Apr 02, 2008
    My is GE model No: GSS25Q FMB BB the coils are inside the freezer section of the fridg. I have tried to switch theromstat/switch for the fresh food three times. Do I need to wait till the defrost starts working. As it has not started working as yet.
I ASSUME YOUR TALKING ABOUT THE COILS BEHIND THE BACK OF THE FREEZER ..IF SO YOUR UNIT IS NOT GOING THROUGH THE DEFROST CYCLE BECAUSE OF A BAD HEATER OR BAD DEFROST TIMER OR BAD DEFROST T STAT .YOU CAN FORCE IT INTO DEFROST BY PUSHING THE FRESH FOOD DOOR SWITCH THREE TIMES IN 15 SECONDS IF YOU HAVE AN ADAPTIVE DEFROST TYPE OF DF CONTROL(ELECTRONIC TYPE).
Posted on Apr 02, 2008
Ge defrost timmer location gss
DEfrost timer is placed beside compression unit, behind refrigerator.
Jul 04, 2013 | Refrigerators
Ice collecting in bottom of Kenmore Coldspot freezer side and then melting and ending up on the floor. It was first discovered by a puddle on the floor. This model--"59282990"--has...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Refrigerators
The refrigerator stays at 47 degrees but the bottom compartments freeze
You have a defrost problem. A blockage of frost in the freezer prevents air flow over the cooling coils there, allowing very cold air to migrate back into the bottom of the refrigerator section. Unload the freezer and remove the back wall, melt the frost off the coils with a hair blower, and check to see if the defrost heater at the bottom of the coils is burnt out. If heater is OK, replace the 1.5 inch long white thermistor located at the very top of the cooling coils.
Feb 12, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer is not freezing anything on my GE GSS 25 LGP side by side.
Do you notice frost on the rear wall of the freezer section 1 foot from the bottom ? If so , then defrost problem . If not , probable board problem .
Jul 17, 2009 | GE GSS25LGP Side by Side Refrigerator
Evaporator coil freezing over
You are probably correct, the auto defrost sub-system is faulty -- and probably the timer. You'll have to take the back panel out of the freezer to see the defrost timer.
Apr 29, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
186 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
