Question about Emerson EWC1902 19 in. TV/VCR Combo
VCR won't accept new recording tape
After removing, tangled but not stuck, recording tape from VCR, it won't accept new recording tape
  • ornchfrog Jun 03, 2008
    mine chewed up a couple of tapes before i decided to chunk the whole business. i unplugged the set from the outlet. a few minutes later, i plugged it back in and haven't had a problem since. go figure. i guess it just needed to reset.
I asked earlyer but i can't find my questin that was submitted earler today i gave you my email address with no results. I want to know where the nearest tv vcr reparemand is to Spencer okla my email is and my phone 580-782-2888 My mother is moving to Spincer Okla. and needs her vcr forward and reverse fixed,in her emerson tv/vcr combo
Posted on Jun 26, 2008
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Vhs tape stuck in vcr
Some one needs to open it to see if the tape is loaded but wrapped around a post or tangled up.
What usually causes this is the mechanism that moves the tape has a problem---bad or broken belt or rubber drive wheel that moves tape is bad.
Its called eating tapes.
With it apart you may be able to extract the tape and then insert with it apart to see if reels etc are or are not moving in RR and FF first and then in play to see what is not moving.
May 26, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Tape is stuck, can't remove it
I remove a stuck tape from a VCR by taking off the outside cover. (My unit was held together by 5 screws.) This allowed me to access the tape and check where it was locked. I had to loosen a twisted tape from the mechanism and then I could eject it. (Note: I unplugged the deck before removing the cover.)
I hope this helps.
(I've been fortunate; I've only had to do this on VCR units (not VCR/DVD) that were out of warranty. If your MWR20V6 is still in warranty, you may not want to open the case at home.)
Dec 17, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr won't accept tape for recording
Check that the recording tab has not been removed.
If it has, use a small piece of masking tape to cover the hole.
Apr 06, 2011 | JVC HM-DH30000U DVHS VCR
VCR tape stuck in machine
This could be a loading basket issue, or the tape has become tangled in the machine. Unplug the vcr, remove the top cover, if you see tape spewed in the mechanical section, plug the power and turn on, now try eject! if you see the tape pulling disconnect power and cut the tape with scissors and remove all the bits and pieces carefully not to damage the video head. If luck is with us the machine hopefully will eject the main cassette. If the tape is not the problem it is a loading issue, probably will need a technician.
Jan 17, 2011 | RCA DRC8335
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Emerson EWC1902 19 in. TV/VCR Combo Logo
133 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
