Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Freezer dying I have a frigidaire upright that is only, maybe, 3 years old. All of a sudden it is not getting cold enough. A ton of my stuff is totally defrosted, but everything is still cool. It's cold enough that my meats haven't defrosted yet, but all my vegies, jellies, jams, etc have. Charity Vickers charityvickers@hughes.net
    Novelist:
  • 184 Answers
IS THE FREEZER AN AUTO DEFROST FREEZER? IF SO, IS THERE FROST BUILT UP ON THE BACK WALL? IF FROST APPEARS ON THE BACK WALL, THERE IS A DEFROST FAILURE. THERE ARE THREE ITEMS IN THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL.
THE TIMER IS USUALLY LOCATED ON THE BACK OF THE FREEZER DOWN NEAR THE COMPRESSOR IN THE CORNER. IT HAS FOUR WIRES ATTACHED TO IT. YOU CAN ADVANCE THE TIMER BY TURNING THE KNOB ON THE FACE OF THE TIMER. WHEN IT CLICKS LOUD AND STOPS THE COMPRESSOR RUNNING, IT IS IN THE DEFROST CYCLE. WAIT 5 MNUTES AND CHECK INSIDE THE FREEZER
TO SEE IF THE HEATER COMES ON. YOU MAY BE ABLE TO HEAR THE FROST MELTING AND DROPPING ON THE HEATER. IT WILL SIZZLE AND POP. ALSO, LOOK FOR A GLOWING DOWN AT THE BOTTOM OF THE BACK PANEL.
IF THE HEATER IS ON, THE TIMER IS BAD. IF NOT, CHECK THE HEATER AND BI-METAL.
IF THE COMPRESSOR IS NOT RUNNING, CHECK THE COLD CONTROL TO SEE IF IT IS GOOD. IF THE COLD CONTROL IS O.K., THE START DEVICE ON THE COMPRESSOR MAY BE BAD. DOES THE COMPRESSOR HUM FOR A MINUTE AND THEN CLICK AND SHUT OFF. IT CAN BE EITHER THE START DEVICE (RELAY) OR THE COMPRESSOR IS BAD.
Posted on Apr 05, 2008
Freezer is 11 years old. Alarm has gone on and freezer is not very cold. Has it died or can it be fixed?
Hi there. I really think it could be a thermostat or a small fault. But jump on Google to look for faults with that model. Let me know how you go
Jun 02, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
Upright self def. freezer not getting cold
Is your compressor running? Try this: place your hand on top the compressor, quickly-in case it's hot-it should be vibrating and cool/warm to the touch. If it's not running then the cheapest/fastest test is to try a 3in1 start kit from a local appliance shop. The 3 in 1 start should be around $14 to $20 to wire up. It's extremely simple to wire up, just ask the clerk at the appliance shop's parts counter and they will explain it. I hope this helps you out!!! :)
Nov 19, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright frostfree freezer stored several years unplugged, restored power last night alarm keeps ringing and freezer is not getting cold.
Clean the unit entirely, coils, filter, etc. Then retry. You might have a faulty control board since it has not been used in many years. All depends on the location and humidity. That can tear up a thermostat and control board.
Jul 28, 2012 | Frigidaire 20.3 cu. ft. Upright Freezer...
My GE upright frost free freezer is not cold enough to freeze food anymore.....its cold but not freezer cold....stuff is defrosting....what could be wrong. I hear it running, but I dont hear it go off...
without getting all technical, look for the condenser coil and be sure it is clean. Some are under the refrigerator and can be accessed by removing a "kick plate." Some are under and in the back and can be accessed by removing a cover with a few screws. Some units have a small fan that moves air over the condenser coil. Look for it and see if it is running. And then there are some that have coils that run up the rear of the unit and when it is pushed back against the wall, the air can not circulate and can cause this issue. This is the simple first step to do before getting a service tech involved.
Dec 16, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
My freezer is not cold enough to keep food frozen...
the "e" usually means it has an error. it could be a bad temperature thermistor or a bad control board. the most likely is the board.
i hope you are less then 1 year old as the board can be quite pricey, about 150 bucks.
you could try to unplug the unit for a few minutes and then plug back in and see if the code goes away and returns to the cooling mode.
Dec 29, 2008 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
273 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
