Brother IntelliFAX 2800 Laser Fax Logo
Posted on Apr 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bad print with repeated text on fax or copies
My 2800 fax went bonkers this morning. We did do alot of faxing yesterday in and out. the print is all dark and the text is repeating down the page. How can I tell if its a drum or fuser problem? Kent
A
Anonymous
Not being able to receive documents from fax
Mac Gyver
Level 2:
  • Expert 168 Answers
  • Posted on Apr 03, 2008
Mac Gyver
Expert
Level 2:
Answers
168
Questions
Helped
89382
Points
427
Make a copy and shut the power off or open a door when the paper is 1/2 way into the machine. You are just basically going to have to try to time it. When you hear paper being fed into your machine (the blank paper from the tray) count about 3-5 seconds and then open a door on the machine or shut the power off. IF you have timed it correctly, the paper should be 1/4 - 1/2 way through the machine. Remove the jammed paper **** But be careful..... The toner is NOT FUSED at this point so it will rub off if you brush it up against your clothes or hands. If the image is doubled at this point.. then its the drum unit. If the image is good at this point, then it is probably your fuser.
Hope this helps.
Good luck.
Mac =)
Print out of faxed copies are too dark AFTER the first 3
You need a new drum unit. The built-in cleaning blade has worn out.
The fax is printing dark black all over the page
It seems that there no charge voltage when copies are made.First thing you can try is to replace the drum unit or the toner cartridge.If this doesn't help,there could be bad charge circuit board that needs to be replaced.
1helpful
We had a paper jam and I got the paper out but now the fax machine is printing out pages that are smeared with black toner
The fusing unit heat roller is damaged or worn out and it needs to be replaced.The roller has non-sticking teflon coating.When this coating is bad,toner start sticking to it and causing jams and bad copy quality.
How to use the Fax option on a Canon imageRunner 2800.
1)firstly place your text onto the platen glass.
2)press the fax mode
3)dial the number by pressing on the control panel keys.
4)listen there is any dial tone.
5)if no dial tone ,fix the fax cable to the machine .
6)repeat the step again.good luck
1helpful
Horizontal lines and tones specks around text
Only known causes are a dirty corona wire or a dirty/bad drum. If you know the drum is good, a thorough cleaning of the drum and cleaning the corona wire should clear up your printing.
When I send a fax from our Brother Intellifax 2800, the person receiving the fax gets the fax but half of the page is blacked out, what is the problem?
sounds like your cis (contact image sensor) which lights up and reads your original, is bad. that component is located under the keypad/control panel. if you make a copy, it should also be partially balck if that is the problem.
razors
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
1helpful
Disable receive mode on FAX-2800
NO the best solution is to turn fax machine off after hours
1helpful
Copied pages are all black
Is is a lower end product for light duty use. You can try a new genuine OEM drum and or toner, but buying them both would cost as much as a new 2800. Can you print a internal report OK?If so, then your scanner is defective. A common problem with 2800,s
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Norman Weimar
Norman Weimar
k24674
