Question about Brother DCP 7010 Multifunction Laser Copier
Brother, DCP 7020
The machine says it needs regular maintenance but I can't find the book. The machine is constantly jamming .
I am having a black line going up and down on my copies. What could that be?
Posted on Aug 19, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
The maint enance message is just that a message telling you you should have a tech come out and change some parts that are most likely wearing out.
Doesn't necessarily have to be done at that time, in your case it corresponds with a jam, the question is where is it jamming? you did not specify.
1- if in the paper tray the tires are not picking up Clean w/alchol or replace
2- if it crumbles at the exit then the fuser has a problem, check heat rollers, and claws ( if making an accordion )
Posted on Jul 23, 2008
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Back cover open message but cover is closed
Sounds like the sensor has been damaged try turning off at wall and re starting if it continues you'll have to go into maintenance mode and reset
Apr 09, 2014 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 paper jams
DCP 7020 PAPER JAMS SOLUTION1... LASER MOTAR DASTE CLEAN LASER MOTAR
Jan 16, 2013 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Paper Jam, we keep having the paper jam at the paper exit at the top/back of machine. I've examined closely from front, back, bottom, even removing a few easily removed parts, but can...
This is caused by dirty exit roller. As this machine is a pain to dismantle I suggest that you try and clean these rollers ( 3 or 4 rubber small ) as they rotate. Opening and closing the front door will keep rotating them for you. Use a damp wrm water lint free cloth. I use a compound named Print Clean but metho can be used also.
May 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 "Back Cover Open" lights up even after it
Try doing a power reset.
Turn off the printer/Unplug it for a few minutes/Plug it back in/Turn it back on.
Jan 11, 2011 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother 7020 printer "fuser error"
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Mar 19, 2008 | Brother DCP-7020 All-In-One Laser Printer
Brother 7020 Fuser does not warm up
dcp-7020 fail to warm - how do i reset if i turned off and on already and waited 10 minutes
Dec 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 7010 Multifunction Laser Copier Logo
183 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
