Question about Dryers
Dryer venting
My dryer is in the basement, is a 90degree angel out the back of the dryer a problem, or should the dryer be on an outside wall where the vent can be straight?
  • 110 Answers
Straight is always better, but if you have to have a 90 degree, it will be find as long as it is not kinked.
thanks
whites appliance repair
Posted on Apr 03, 2008
I currently live in the midwest and today has been an extremely humid day (90 degrees+ and 84%+ humidity). I used our LG gas dryer (Model # DLG2241W) earlier this weekend and it worked fine. Tonight, when...
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
Please let me know if I can help further.
Jul 18, 2011 | LG Dryers
Is there a way to vent a basement bathroom without cutting into the cement foundation
What is in the room above the basement bathroom?
And how large is the diameter of the vent pipe you need to run?
Do you have a maximum number of elbows, and runs of feet maximum you can't exceed?
Is the Frame wall above the foundation, accessible by going up thru the ceiling of the bathroom, and the elbowing over and into the outrside frame wall at that point?-- and then up a ways, and then out thru the outside wall?
Another possibility would be: How far to a window, or vent already in the basement?-- Could you run the piping there, and then out?
How thick is the concrete wall?-- Is it reinforced Concrete-- or just Masonry Block wall? A block wall is not as hard to get thru--
I know I asked a lot of questions-- but maybe it helps you think thru your options?
Le4t me know if I can help further.
Mack B
Jan 29, 2011 | Fantech Fans Exhaust Fan In-Line
Water build up nin dryer vent
Hi, W/D here.
It would be best in your circumstance to slope your vent like one might slope a drain. 35 feet is waaaaay too long, 20 feet is max, and you can deduct 6 feet for every bend. If you can reconfigure your vent to a sloped drain, this will help.
The coolness of the basement is a contributing factor, but normally, it doesn't figure into the issue.
If you cannot shorten your run, or slope your line, you might do well with a trap that would have a mini sump pump in it. These are available from A/C companies, and are automatic in their operation. I have had one in one of my units, and the cost wasn't unreasonable. You can probably find one on-line (EBay?)
Venting into the basement may resolve your water issue, but you still have to deal with the lint that "escapes" the lint trap. Most of it will likely wind up in the air conditioner, and all over whatever you have in your basement.
A mini sump sounds like your best option, even if you have to set up a schedule to clean it out occasionally.
Best regards, --W/D--
Aug 12, 2009 | Maytag Dryers
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
Used to dry quicker
ck vent hose behind dryer to be sure it's no mashed or crimped may be too close to wall then ck vent to outside too long or too many bends will reduce air flow to outside
Aug 19, 2008 | LG DLE2532W Electric Dryer
Air vent
Many home improvement stores such as Home Depot , Lowes etc carry Vent kits. I would encourage you to pick up one of these and install it through your outside wall. Normally, the outside portion of the vent has a flapper to keep outside air and critters from coming into your house when that vent is not in use and also has a short section of ( typically) 4 inch vent line that projects through the wall cavity and into the living space. Most flex lines should be atteched to that. If you are usintg a gas dryer, it is strongly encouraged and may be code requirements in some areas to use only solid ducting to the outside. Electric Dryers do not have the same exhaust gases and can be ducted with a plastic flex line. Hope that helps...
Aug 12, 2008 | Dryers
Renovating my basement,and planning for a gas dryer. Whatkind of in-wallconnectionsshould be used, and location on wall for a stackable waher/dryer system?
you need to first find out the best method of running your gas line to the location of your dryer..Make sure you also run a vent hose to dryer to the outside of your house, make sure you have 120 volt outlet, i would also run a 220 line as well just in case you need 220...
marclavoris
Apr 02, 2008 | Dryers
Dryer Doesn't Dry Well: Take two full drying cycles.
if at all possible disconnect vent from behind machine and run a cycle with wet clothes( lint and moisture will be fllying around whih is why i said if possible) if it works then you know there a restriction in vent line leaving the home. Most problems relate to poor/ innadequate venting!!!!!!
Mar 02, 2008 | Frigidaire FLEB8200DS Top Load Stacked...
I have a lg dryer model dlg2532w gas dryer it does get warm
if the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
Sep 25, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
Top Dryers Experts
