Question about Dell Latitude CPX650 Notebook
Key board not writing as stated
The key board not responding to what is typing and key board seazed
Sometimes my i,k and 8 keys do not function when pressed. It seems to be sporadic.
  • 106 Answers
Liklely dust on ur keyboard, use a blower....
Posted on Apr 02, 2008
6ya staff
SOURCE:
Text writing is weird. I write and part of the word appears a sentence away?
Ha, it's because your wrist or thumb is touching the mousepad occasionally - some are more sensitive than others.
Try turning the mousepad off while typing, sometimes there is a button at the mousepad area, others it's an Alt-Function key. Look for a symbol on the F-keys that look like a finger touching a square or mousepad. This, and the Alt key combination will shut it off and then back on again when you select them.
An external or USB keyboard and mouse works great for me.
May 08, 2014 | Computers & Internet
Hi, am ganesh functions keys
If those are the only keys on the key board that are not responding, I would try to
1. boot in safe mode and check response. If you have other keys on the laptop that are not working,
2. I would boot operating system from a flash drive and check
and if both still are not working for you
3.try an external key board
Last replace the key board
Hope this helps
Sep 05, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
You state to hold the fn, and hit the power button.....OK, whats the ( fn ) key ?
The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
Feb 01, 2011 | Dell Inspiron 6400 Notebook
How to handle the walk man wen the sighn of hold again and again comes and we are un able to pres any button
to deactivate the HOLD function is usually possible by a key switching to off state. There are cases when the function is managed a certain key combination which has to be described in your manual.
If you can not solve the problem you should write the exact type of your item
Bye, gylacz
Feb 01, 2011 | Audio Players & Recorders
Sometimes the keys that have white and blue writing on them will only respond blue. How do i get them to respond as white instead of blue keys?
You have a FNC key on your keyboard. Since it is a laptop, your keyboard can not have all the keys that a normal keyboard has. This is handled by making some keys perform two or more functions. Thus, the alternate key use if the blue keys (function key is depressed). You will pribably find that there is a light labeled as FNC where you see your caps lock, num lock etc.. it sounds to me that you have your keyboard in alternate function mode so that the keys are performing the alternate functions (probably the numeric keys if it is a normal configuration..).
Thanks!
Stan Skaggs
Oct 19, 2009 | HP Pavillion G50-111NR Notebook
Key not turning
your tumblers may be starting to seaze up. try spraying some lube in it and running the key in and out a few times. and also make sure the steering isnt locked and the gearshift is all the way in park ( if it is a automatic)
Feb 16, 2009 | 1997 Saturn SL
TI-89
If you make a custom, you can have the Toolbar F function keys operate as 7, 8, & 9. If you respond with a rating I'd even write one out for you, and make it where you just hit [2nd] [CUSTOM] for the use of those keys.
Oct 03, 2008 | Texas Instruments TI-89 Calculator
uninstall keyboard drivers from device manager and click scan for hardware changes automatically it will take drivers,again same problem will come attach the external keyboard and check if work keyboard problem on laptop
Mar 11, 2008 | Dell Latitude C640 Notebook
Enabling my Emachine keyboard functions
Sounds the The F lock is on when your computers starts up, You should see a number or F lock on top or your key board just press that button to disable and let you f keys work again, It must be on in your bios if some one there is computer savoy enough to go into your bios and change the setting so when you boot up next time that won't happen anymore, Ok if thats don't work just write back here and we will try another easy task, Let me Know. We try to keep it a simple as possible, Ok Thanks so much and Happy New Year
Dec 25, 2007 | E-Machines eMachines Desktop PC
Non functioning keys
Have you tried to run the Dell Diagnostics? If YES, what were the results? If NO, please run the DELL Diagnostics and tell me the results. thanks
Mar 14, 2007 | Dell Latitude D800 Notebook
Dell Latitude CPX650 Notebook Logo
138 people viewed this question
Ekse
Clive
Clive
Alun Cox
