Question about Gateway FPD2275W LCD Monitor
Monitor My Monitor turns on just fine and last for about 20 to 30 mins and then just shuts off. The Power light stays on like it is still on but nothing showing on the display. Turn the Monitor off for about 5 to 10 mins and then turn back on and it comes back on then goes out again in about 20 to 30 mins. Not sure what is going on.
  • 2,785 Answers
Try by uninstalling the video driver from safe mode and reinstall the driver.if the problem persist then your monitor needs servicing
Posted on Apr 03, 2008
Pc won't start
Think your power supply died. Check that out first since they are relatively inexpensive. Or throw in a known working PS to see if that does the trick. Write back with results for further info.
Sep 17, 2017 | Packard Bell iMedia Computers & Internet
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
AMW 199B monitor takes forever to come on
My AMW 199B shuts down.On button shows no light.If push on button nothing happens.So I unplug it and it will come and stay on for a long time,(last time a day), then all of a sudden it will shut down
Aug 04, 2009 | Advueu Technology AMW-F196B
Monitor shuts off during use
3 years old and generally rated as a Mediocre monitor to begin with, I'd say I'd invest in a new monitor
Here are some replacement options:
Sep 10, 2008 | BenQ FP72G+ 17" LCD Monitor
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor shuts off but green light stays on
I perhaps can. I would think inverter or ccfl's.
Jun 12, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Blank screen
Similar monitor, similar problem. I actually had to dismantle the thing and replace a transistor on the mainboard.
If you're not into soldering and such, good luck.
Oct 03, 2006 | Mag Innovision LT776s 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
141 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
