Question about HP DesignJet 450c InkJet Printer
Data light and Cartridge light stays on
I have just bought used printer and have downloaded the software for XP. Now, data and cartridge lights stays on and it doesn't print.
  • 1 more comment
  • ivy6 Jul 17, 2008
    I have cleaned the cartridges and the cartridge error light still stays on??
    And doesn't want to print.
  • Anonymous Aug 31, 2008
    I am having the same problem and I have not used it in a while. Cleaned all contacts 3 or 4 times
  • kellyrr87 Oct 07, 2008
    i have the same problem, i turn it on and sometimes it will "rewind the paper" so that it is out of the machine, and it always has the data and cart. orange lights turn on. if i press cancel the ready light blinks green but wont print
As hundew wrote, the "mark encoder" is not detected. Cartridge and Data lights are on.The ready light also. If you cancel it, Load media will appear.
In my case the optical sensor on the carriage was never over this encoder as the roll moved forward and back so it could never see it(probably a faulty default position). Therfore I tried to push the encoder a
litle bit away from the roll with a screwdriver that the optic.sensor can better see it.
And its working now. :)
You can also try to move the carriage with the hand in a right position over the marker as the printer is seeking for it.
Posted on Nov 18, 2008
    Problem Solver:
  • 7 Answers
If ready is also on it indicates that the "mark encoder" is not detected.The mark encoder is the white plastic piece on the left end of the large black roller that the paper feeds around.If the encoder is very dirty,then cleaning may help.If cleaning does not work the solution is to replace the carriage.Good luck.
Posted on Aug 28, 2008
    Problem Solver:
  • 5 Answers
You are missing one more light, Ready, Load media or Align media? It makes a differance
Posted on Jul 28, 2008
  • 42 Answers
Clean off cartridge contacts on printer carriage where carts sit and contacts on cartridges-if they sit for long periods of time they clog up.
you will probably need new cartridge{s}
start with black and go from there.
we use alcohol.
Posted on Apr 22, 2008
I have hp designjet 450c plotter which is in use by me for over a year now, but the data and the cartridge lights stay on and does'nt print since the beginning of this week
Posted on Jul 27, 2008
Error & data light on solid
Alarm and Data lights both on solid indicates, out of toner. Toner cartridge needs replacing. Visit the link below to download a user manual for your printer.
Hope this helps.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002139/Eng1030ug.pdf
Jan 21, 2011 | Brother HL 1240 Printer
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
Epson Stylus CX7400 Ink Light Problem
You need to open up the maintenance window and go thru the motions that you are changing the cartridges and this resets the ink levels back to full and sends data to the printer saying that they are full and the ink light disappears and it prints fine !!!
Just changing them doesn't seem to do the trick like on a lot of printers
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
Turn on the printer.
Watch the control panel.
When the memory starts counting, press and hold the green (Select) button.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE.
Press (Down Arrow) button once. The control panel will display COLD RESET.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Jan 15, 2009 | HP LaserJet 4600dn Color Printer
Canon pixma mp210 printer - replaced ink cartridges with compatible ones - printer working fine except when printing both ink lamps come on solidly, not blinking, and status says there is no ink in...
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
Nov 08, 2008 | Office Equipment & Supplies
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Printer not working
On this printer, the alarm and data lights mean that the toner cartridge is empty. When you replace the toner, be sure to slide the corona wire cleaner across and back. This is the small light blue plastic piece on top of the drum cartridge. You'll see a small arrow in the plastic. Just slide it back and forth once or twice each time you replace the toner cartridge.
May 11, 2008 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
HP DesignJet 450c InkJet Printer Logo
700 people viewed this question
Seeker5211
Seeker5211
