Question about Microwave Ovens
I have to replace a broken front panel of my kitchenaid microwave hood , i have a new panel
  • Microwave Ovens Master
  • 9,098 Answers
We have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa:
You can usually find helpful exploded view diagrams by entering your full model number here:
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
(Remove the grille from across the top, remove the top screw in the control panel frame, then lift up & out).
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off.
You have to make sure all the old adhesive is off or the new keypad will not stick.
I use paint thinner or mineral spirits, then follow up with isopropyl alcohol to be sure the panel face is squeaky clean and dry.
Then peel the backing paper from the new keypad and carefully press the new keypad in place.
You need to be precise - you cannot apply it, peel it off, then reapply it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 02, 2008
How-To Replace The Door Handle On A Kitchenaid Microwave Hood
behind door their is trim round the door use flat knife go between the trim will pop out and open 2 sc
Feb 01, 2015 | KitchenAid KHMS2050SSS Microwave Oven
Having touch-pad problems with my KitchenAid KHMS2056SSS-0 range hood microwave. It's an intermittent problem where the touchpad activates itself and activates menu items.. and beeps each time. Resetting...
Usually the top vent front panel is held in by two screws and or clips, Get those off and the bottom of this peace should un hook, unless there are screws there also. if you can get this far, the rest will be obvious.
Oct 20, 2013 | KitchenAid Microwave Ovens
Door wont latch
Possible that the lock switch had broken or that the alignment of the lock is offset. You can remove the front panel by removing the screws on the sides and slide out the panel to get a view of the lock which wil confirm the case. If so the lock must be replaced or if broken and the piece is found within , it can be stuck together using instant glue.
Jan 11, 2013 | KitchenAid KHMC1857WSS Microwave Oven
How to replace clock display on #KBMS1454RSS
You can find helpful exploded view diagrams here.
Dec 10, 2012 | KitchenAid Microwave Ovens
How to replace a Broken Door Handle
This website has the parts you may need.
Some screw in from the front, while some screw in from the back. You may have to call an appliance repair technician to put in the door.
Dec 07, 2010 | KitchenAid KHMS155L Microwave Oven
The door handle is broken on model khms 105ebl0 kitchenaid
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 04, 2009 | KitchenAid KHMS147 Microwave Oven
Kitchenaid microwave hood combo KHMS155LSS
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; while you are on vacation or at work or at night while you are sleeping etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying logic self start defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful. Also, please go to the Consumer Product Safety Commision website at and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess. Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
Jan 02, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 24, 2008 | KitchenAid KHMS147HS Microwave Oven
How do you get the front panel off to replace the door release latch
You will need a T20 x 100mm Torx Wrench to remove the 4-5 security screws that hold the top "hood" on the microwave unit. I could not find the wrench at Home Depot or Lowe's but it was available at Harbor Freight tools. Its also found easily on the Internet. Its about $10 for a set of 5-10 different sizes.
After removing the screw, and removing the hood, the rest is pretty simple. The left side (looking from the rear of the unit) will be completely exposed now. Be careful not to touch the Magnetron, Transformer, and other wiring to the unit as everything is on this left side.
You will have to unscrew one screw on the top of the control panel that attaches it to the main unit. Once that screw is off, you have to carefully disconnect 3 electrical connectors on the circuit board, then you just have to pull the control board up and out, as there are a couple of latches on the bottom that hooks it onto the frame.
Oct 21, 2008 | KitchenAid KCMS145J Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
