Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100 Spin Hot
I have the Grey/Silver version of this unit. THe machine settings for cycles and washes has disappered from the front of the unit, due to cleaning.
Does anyone know where i might get a copy of this template?
Hot point suuggested i buy a new control panel with the template on it.
  • Anonymous Aug 20, 2008
    can't see the settings to be able to write them back on!
    Genius:
  • 1,554 Answers
Use a label maker they cost 15 to 20 and the labels last forever.
there are ways to stencil them on but they will come off unless you use plastic paint.
Posted on Apr 13, 2008
Hotpoint WF100 doesn't spin
its a stretch fit belt ,give it some application and it will fit
Dec 01, 2012 | Washing Machines
Aquarious wd63 washing getting grey stains at end of wash cycle
Hi.
Can you tell me? Does the washing machine sound noisier than normal in spin? Does it sound rough?
The grey marks could be drum bearing wear causing oil from the bearing to enter the washing machine. Sometimes you may see grey or black dots on your clothing.
If this is the case then repair cost is typically around £100 depending on where you live.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint Aquarius WD63 Front Load...
Wash enhance and on off light flashing.
solved it - kinked hose issue as well i think - hose had being lying loose behind machine - makes sense to attach hose to clips on machine.
Sep 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Looking to download hotpoint aquarius wf100 manual
Hotpoint user manuals can be downloaded from there web site at
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
If the link does not work miss out the bit from /hs onward and navigate through the site to the manuals download.
Apr 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf100 completely dead
have you check the glass fuse on the circuit board it might be at the bottom
shaun
Mar 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Firstly, there should be only one hose, always connected to the cold supply.
The unit will heat the water to the setting you choose for the wash (40 - 60 - etc)
Secondly, if the unit is leaking water, try turning down the cold pressure, this will slow the supply pressure to the unit and prevent spray out from the detergent drawer.
Your supply tap should have an isloting tap on it, adjust this until it sullpies water at an acceptable rate.
Do this by feeding the hose into a bucket/basin and tweak it until it pours out - not sprays out.
This should alleviate any leaks around the machine.
Hope this helps.
Oct 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
98 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
