Failure to load
When I turn it on it shows the screen with Acer and at the bottom it says press F2 to enter setup and it just stuck there.It doesn't want to go into setup or anything. It doesn't seem to load. Pls can you help,I've only had it for 2days!!!
  • Gogga21 Apr 02, 2008
    Do i have to get a New battery? Its only 2days old.
    Problem Solver:
  • 12 Answers
You have to replaced you BIOS battery, after that problem can be solved.
Posted on Apr 02, 2008
Compaq stuck in utility mode
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 14, 2013 | Compaq Armada 1750 Notebook
Computer does not boot:
Press [F2] when you see the message, and see if it will enter the BIOS. See if it detects your Hard Drive....it does not appear to.
you may have a bad hard drive or a corrupted boot sector. Take to a repair shop and they can test the hard drive for you.
Sep 04, 2012 | Acer Aspire One Netbook
My m45se does not show anything on the screen, but the blue light shows that is on and i tried with another ram and processor.
when you turn on , press F2 and DELETE / F2,Del, F2, Del, F2, Del/, it will enter to setup, in it see where "Load setup defaults'', do it then press F10, save and exit.
May 30, 2011 | Computers & Internet
My Acer D250 netbook starts show a white screen the reboots it self, sometimes it not only shows white screen but also gray or it run colourful lines then it restart. When it restart it start working fine...
Suggest using Acer eRecovery Management to attempt problem resolution as follows...
1. begin with the D250 powered off ...
2. if present, remove any external monitor (unplug its VGA connector from D250 left side)
3. power on and immediately press F2 to enter the BIOS / setup utility
4. using the right cursor key, cursor over to the Main tab of the InsydeH20 Setup Utility
5. if D2D Recovery is not enabled, cursor down to it, press Enter key and enable in pop-up
6. save any changes by pressing F10 to save and exit, otherwise press Esc to just exit
7. press Alt and F10 together while the Acer logo is showing to get entry into eRecovery.
8. eRecovery entry is indicated by message at bottom of screen "Windows is loading files...".
9. if not successful, power off, wait a minute then power on again and immediately
10. press Alt and F10 at the same time - do this several times while Acer logo showing.
11. once in Acer eRecovery Management (V7.0.10) screen, just leave it there........
12. if after a day or so, the screen has not changed, the problem is likely NOT hardware.
13. on the other hand, if your screen problem occurs after awhile, then it is hardware.
14. if it is not hardware, then your Operating System is likely corrupt or has a virus.
15. If it is not a hardware problem, you can completely restore system to factory defaults.
16. board level hardware repairs best done by sending D250 to Acer's authorized shops.
Dec 28, 2010 | Acer Aspire One PC Notebook
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
Aspire 5610 stuck on initial Acer loading screen!
Time to re-install your OS.
Install Windows from Bootable CD.
May 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer descktop t-180 stuck on "verifying DMI pool DATA"
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
Jan 06, 2008 | Acer Aspire T310 PC Desktop
BIOS setup
hit F2 continuesly when the acer boot logo shows on the screen...thats all.
Dec 12, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
