Question about HP 920 Plain Paper Fax
HP 920 Fax Half Lines
Hello! All the incoming faxes are coming in with half the line printed (bottom half). Any suggestions? Thanks for your time.
  • 168 Answers
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Posted on Apr 03, 2008
SOURCE:
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
The orange light keeps flickering. I checked to see if any paper is stuck but couldn't see anything. There's something preventing the printing process. What could it be? Need help. Thanks
hello
which one of these HP p/n's is your fax ? C4647A or C4649A
is this your fax ?
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649A
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649Apic00602.gif
go to this link , follow instructions, -- HW TO CLEAR PAPER JAM
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu50320&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=60718
please rate my service
Nov 05, 2010 | HP 920 Plain Paper Fax
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
How do you load document to send fax. With letter facing you or facing down. Model HP 920
There should be an icon on the device showing a rectangle and what appears to be a triangle on top of it. This is showing you a folded page. If there are no lines on the rectangle with lines on the triangle then you insert the page face down (print on page towards the device) if the rectangle has the lines and the triangle doesn't, you insert face up (print facing you while in the inserting into the machine)
If you have any more concerns address your owners manual, this can usually be found on a CD that came with your printer or at HP's support website.
Let us know if you have any other issues.
Apr 16, 2009 | HP 920 Plain Paper Fax
Life of a 920?
As long as they still make the ink for them.
Aug 29, 2008 | HP 920 Plain Paper Fax
Printing of incoming faxes
I have the same problem on my hp all-in-one. it looks like a staple went through the copier and it shows on incoming faxes as well...
May 21, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Dark toner streaks
can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
BLACK INK LINES ON INCOMING FAXES KX-FL511
It's time to change NEW DRUM UNIT..and that's why your Toner will Not Last Longer because unnecessary toner (the black lines) will be on the copy every time the fax comes or you make a copy.
Oct 01, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP 920 Plain Paper Fax Logo
125 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
