Question about Epson Stylus C60 InkJet Printer
New ink, not printin Jam in the queue
I have just installed a brand new EpsonT029 color ink cartridge, cleaned the heads, and realligned the nozzles. I also have an error message coming up that there is a line of messages in the printing queue.
I have deleted all of the data in the queue, but still, it says that I have one in reserve. I can not clear that off of the machine I do not know how to get that one out of the queue.
Shouldn't a new brand name cartridge print out just fine?
Help greatly appreciated.
  • 26 Answers
Hey Justmeme
It would be helpful if you tell me what you did to clean the heads and realligne the nozzles. And did you go to cancel all documents to remove all waiting to be printed items?
Dave
Posted on Apr 02, 2008
SOURCE:
Cleaning head and nozzles
Cleaning the Print Head
r_bullet.gifUsing the Head Cleaning utility
r_bullet.gifUsing the control panel buttons
If you find that the printout is unexpectedly faint or some dots are missing, you may be able to solve these problems by cleaning the print head, which ensures that the nozzles are delivering ink properly.
You can clean the print head from your computer using the Head Cleaning utility in the printer software or from this product itself by using the control panel buttons.
  • Print head cleaning uses both color and black inks. To avoid wasting ink, clean the print head only if the copy quality drops (for example, blurred printout, incorrect or missing color.)
  • Use the nozzle check first to confirm that the print head needs to be cleaned. This saves ink.
  • When the Error light is on and a message appears on the LCD panel to prompt you to replace the ink cartridge or to indicate the ink is low, you cannot clean the print head. In this case, replace the appropriate ink cartridge first.
Refer to the appropriate section below to use the Head Cleaning utility.
For Windows
Follow the steps below to clean the print head using the Head Cleaning utility.
r_1.gifMake sure that A4 or Letter size paper is loaded in the sheet feeder.
r_2.gifMake sure that this product is on and the ! Error light is off.
r_3.gifAccess the printer software.r_arrow2.gifAccessing the Printer Software for Windows
r_4.gifClick the Maintenance tab, then click the Head Cleaning button.
r_5.gifFollow the on-screen instructions.
Head cleaning... appears on the LCD panel while this product performs the cleaning cycle.
r_space.gifr_caut.gifCaution:r_space.gifr_space.gifNever turn off this product while Head cleaning... appears on the LCD panel. Doing so may damage this product.
r_6.gifWhen Head cleaning... disappears from the LCD panel, click Print Nozzle Check Pattern in the Head Cleaning dialog box to confirm that the print head is clean.
Good: print head does not need to be cleaned yet.
Not Good: print head needs to be cleaned.
If the nozzle check page does not print satisfactorily, you may need to repeat the head cleaning and print the nozzle check pattern again. See Cleaning the Print Head.
  • If the copy quality has not improved after repeating this procedure four or five times, turn this product off and leave it alone overnight. Then, perform the nozzle check again and repeat the head cleaning if necessary.
  • If the copy quality still has not improved, one or both of your ink cartridges may be old or damaged and may need to be replaced. To replace an ink cartridge before it is empty, see Replacing an Ink Cartridge. If the copy quality remains a problem after replacing the ink cartridges, contact your dealer.
  • To maintain good copy quality, we recommend copying a few pages at least once every month.
Apr 14, 2013 | Epson Stylus CX6400 All-In-One InkJet...
I have a ip3000. It suddenly stopped printing. The paper comes through but it is blank. I tried replacing the black cartridge (even though it was 3/4 full)and tried uninstalling and reinstalling the...
how old is the cartridge thats in it? If you have had it a while, they do go bad. Also, make sure that you have pulled the tab off of the cartridge. The nozzles are probably really clogged.
You can try this, it usually works, but is some times not worth the trouble.
Use rubbing alcohol and clean the nozzle on the cartridge untill it works again. Wet a paper towel with alcohol and rub the nozzle on the cartridge and you will see it Ink coming off onto the towel.
You may have to repeat several times and then do a nozzle purg(clean) mode on the printer.
It should make it work again, but it may not be the best quality.
As well, some times they do read incorrect ink levels.
If all else fails, you will have to buy a new black ink.
Dec 05, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Message says Remove and check color cartridge. We
The cartridge cavity in the printer may need cleaning.... perhaps a colorful "spit wad" is lodged in the cavity.
If the printer will allow, run a "clean nozzle" utility from the printer or computer.
Hope this helps!
Sep 08, 2009 | HP Officejet 7210 All-In-One InkJet...
Epson PictureMate - can't clean all nozzles & Error P
Many times head cleaning will throw much ink away. 1 time about 10% of ink. After meny times head cleaning, ink will out, and need replacement. May be after head cleaning nozzle is ok, but after replacement, printer do ink charge. It may be distrub the flow of ink at head. Is the cartridge new?. Use CISS for continuity printing.
Jul 26, 2009 | Epson PictureMate C11C623001 Photo Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Color cartridge stopped working.
Try cleaning the contacts on both the ink cartridge and the carriage with a cotton swab dipped in alcohol. If that does not work, the nozzles on the color ink cartridge may be clogged with dry ink.
There is a nozzle cleaning utility in the Lexmark Solutions Center. Use that to clean the nozzles of your ink cartridges. The Lexmark Solutions Center is installed on your computer. You can find it in the Windows Start Menu under "All Programs" in a folder marked "Lexmark".
If your printer has been sitting without use for more than a few weeks, the nozzles may be too clogged with dry ink to clean by conventional means.
It nothing works, replace the color ink cartridge.
Apr 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
This is not a joke! I've owned 3 premier HP ink-jet printers and each one broke under extremely suspicious circumstances. They provide a very limited amount of use time, and their cartridges are severely OVERPRICED!
I believe that anyone reading this should look at their HP, and replace it with a "Brother", "Lexmark", "Kodak", or other reputable company that provides a "DURIBLE" product.
HP is a huge brand name, and they have established themselves for their ease of use. But a printer is not a pair of shoes that should be changed every year or 2. They are poorly constructed, and they get back every penny you save on them by overcharging on the ink.
HP should PAY for betraying their costumers trust, and simply "Lose" their customers! Kodak is better anyways! HP is a second rate product with first rate "BRAND RECOGNITION".
Jun 23, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Epson Stylus C60 InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
