Flat Screen monitor keeps going black - Computers & Internet
  • koepfler Nov 19, 2008
    Power is not lost but screen "shuts off"
  • schwab518 Jan 12, 2009
    The screen simply goes blank for 1-5 seconds once or twice a day. (It seems the frequency has increased over the last month.) It has always come back so far with no changes or other problems.
    Sergeant:
    Champion:
  • 427 Answers
Make sure that the power cord is plugged in firmly and isn't being pulled tightly by anything. Also, make sure anything isn't toughing the monitor's power button. Also, try plugging the monitor into a new power outlet.
Posted on Apr 02, 2008
SOURCE:
Monitor going to sleep
Hey how r u?.............One reason your monitor keeps doing this is because your monitor has a shortage in its cords. This might make the monitor have a mid of its own.
Apr 10, 2014 | Polaroid Televison & Video
My acer flat screen monitor thats brand new keeps going black on me
It sounds like the inverter is on the way out and hence the black screen. It needs that unit replaced. However if it was mine and new I would insist on a replacement monitor.
Jan 19, 2011 | Acer AL1715 17" LCD Monitor
Computer was working, then the monitor went black and the yellow lights keeps flashing. The screen also seems to be pulsing. Whats wrong with it?
Have you tried another monitor??
If stil no go then may be video card.
I do not understand "the screen is pulsing"
Jan 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
I keep on pulling in the monitor to my labtop. An
Sounds like your video settings are out of range. Start up your laptop in 'safe' mode, set the video to 1200x1024 and 60Hz then reboot normally.
Post back on the results.
Dec 01, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
My screen keeps going black any ideas?
If it's not showing anything and goes to sleep mode, then did you try to select the proper input from the monitor's on-screen menu?
Otherwise I can't help you unless you are more specific - when does it go black, right away or after 10 minutes of watching a movie for example?...
Oct 26, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Hi my ho nx9005 laptop screen keeps flickering
you have a problem with your flat it is a cable connecting the monitor to the notebook itself and may be damaged or not fixed in it's place
Oct 26, 2009 | HP Computers & Internet
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor keep going to black screen while viewing.
Disable the Screen Saver in the Display Properties from Control Panel of your Computer.
A Black ScreenSaver is active in your Display Settings. Change it to "NONE" and your problem will be solved.
Apr 22, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
112 people viewed this question
Ekse
Alun Cox
