Question about Garmin nuvi 200W GPS Receiver
Unit Cuts Off
I just got my Garmin nuvi 200w unit and when I cut it on it cuts right back off, I tried holding down the right corner and turning on the unit to reset it, it says its clear but it cuts right back off, I tried holding the power on and the white screens appear, I tried to touch the dots but it cuts off before I can complete the reset, Can you Help? Please, Thanks
Sent unit back to Garmin.
Posted on Apr 03, 2008
My garmin 200 gps is not coming on?
Try performing a soft reset on the unit.
Resetting Your nüvi
If your unit stops responding, turn off the unit, and then turn it back on. If this does not help, perform a reset using the reset button on the bottom of the unit.
Caution: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage your unit.
1. Disconnect the nüvi from external power.
2. Press the Reset button on the bottom of the nüvi.
3. Connect the nüvi to a power source.
A hard reset can also be done but will erase all the user data.
This is done by with the unit off and pressing and holding the bottom right hand corner of the screen while turning the unit on.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Sep 15, 2011 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 255W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260,...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 255W GPS unit.
I hope that helps.
______________________
Backup & Restore Nuvi Favorites here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Garmin Nuvi 200W Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
You have now performed a hard reset of your Garmin Nuvi 200 and 205 series GPS unit.
I hope that helps.
on Apr 18, 2010 | Garmin nuvi 200W GPS Receiver
Cuts on start loading then gose out
Reset the unit by sliding the power button the the left and hold it at that position for 15 seconds, then release.
Aug 18, 2010 | Garmin nuvi 200W GPS Receiver
My nuvi 205 touch screen is acting up
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 200 Hard Reset Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W,...
I hope that helps.
Download Nuvi 200 Manuals here.
on Apr 17, 2010 | Garmin nuviĀ® 200 Car GPS Receiver
Bought a Garmin Nuvi 200W Turn it on and all it says is No maps loaded..blah blah...It won't do anything!??!
If you just bought it, then you should take it back and have it exchanged. No need trying to fiddle with something that is new, when it can easily be exchanged. Sure, you can call Garmin, wait on hold and have them fix it for you but it will be much easier to exchange the unit. This is not normal for a new unit right out of the box.
- Jim
SHARCNET-USA
Jan 05, 2010 | Garmin nuvi 200W GPS Receiver
I have a Garmin Nuvi 200 and I just bought it from the pawn shop. It is locked...Can someone help me please and thank you.
I am not sure if this will work for a locked unit, but try, with unit OFF, pressing bottom right corner of the screen with your thumb. While still holding down on the screen with your thumb switch the power on and this MAY reset the unit and give you access to the unit. If this does not work call Garmin support at 800-800-1020 and they may be able to help. Good luck.
Jul 07, 2009 | Garmin nuvi 200W GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 200w
Found this thru Garmin support
Question: Why will my nüvi 2xx not find satellite signals?
Answer:
p>If your nuvi 2xx is not acquiring satellite signals, you may need to download and run our WebUpdater program.
Go to:
http://www.garmin.com/products/webupdater/
If you are still having issues after updating the software on your unit, you may need to do a full master reset. Please note that a master reset erases Favorites and waypoints. Before proceeding, you may want to back up information you want to keep.
To do a full master reset to the nuvi 200 series unit:
1. Turn off the device.
2. Place your fingertip or the eraser end of a pencil in the bottom right corner of the touchscreen.
3. Apply pressure in the bottom right corner of the screen.
4. While pressing down on the screen, power on the unit and continue pressing on the screen. A message displays to confirm that you really want to delete all user data.
5. Touch Yes.
6. Your unit restarts automatically. You must go through the set up procedure again.
Once you complete the reset, place the nuvi unit outside where it has a clear unobstructed view of the sky for 15-30 minutes. Keep it in a stationary position until it reacquires satellites.
May 20, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
133 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
