Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon inkjet printer
The paper passes through the printer very fast but does not print
  • 655 Answers
1. Check out the ink cartridge, it might be blank.
2. Reset Your Printer:
  • Remove power supply
  • Leave it for few min.
  • Then re-connect.
And try again
Thanks
Iqbal
Posted on Apr 02, 2008
  • 4,102 Answers
Have you tried reinstalling the software and also when you look at the print preview before printing does it show you what should be printed check this then get back to me ok
  • Canon Master
  • 19,396 Answers
Did you changed the ink cartridges?
  • Ginko
    Ginko Apr 02, 2008
    Check first that is not just a cartridge problem, eventually replacing them. if they are not empty , they could have dried up.
    If it is not a cartridge problem you may need to re install the drivers from your printer diskkd. If you do not have the cds, you will need to download the drivers. To reinstall
    Disconnect the printer from usb.
    Remove the printer from 'installed printers' in Windows.
    Insert the printer cd, or start the downloaded drivers.
    Plug back the printer only after reinstalling software, or when required by setup program.
    Finally, if all the above did not work (you can try couple of times with drivers, just in case), it may be a problem with the hardware. An head may need to be cleaned or replaced. In this case you may consider contacting a service.
    Regards
Canon i9950 inkjet printer, keeps showing paper jam even though nothing there. If I turn it off and on, it prints anything from 1 to 4 pages before error message paper jam again. Just going round in...
Maybe it's just one small paper.
If it's on guarantee, take it to store, and describe the problem like this:
"Cant print. Don't know whats going on!"
So they don't charge you ;)
If it's out of guarantee, try to open all parts until you see the small paper.
Or it could be the sensor (piece of plastic) that was jammed, or get jammed when paper pass. Take a good look on that too.
Aug 27, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
Ip6700d won't print
Dear sir arthur,
Paper feed problem is usually caused by broken sheet feeder unit. But if you can print nozzle check pattern successfully it seems that paper cam sensor broken so it cannot reach paper end properly.Rarely, faulty paper feed sensor may cause the same problem.
Regards,
Nov 30, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon BJC-2110 Printer
Try cleaning the nozzle using the software that came with the printer, if it's been a while since you have printed, try cleaning the head with a cotton swab and some isopropyl alcohol.
Aug 25, 2008 | Canon BJC 2100 InkJet Printer
Printer is spitting paper out.
reinstall your software tha came with the printer
first then see how it performs
Jun 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer is catching on the bottom right section of paper when printing
when was the last time you changed the cartridge/inkhead could be ink buildup and causing it to snag Inkjets are horrible about drying and clogging. if inkhead is removeable you may take it off and clean the area that comes in contact or proximity to the paper, I would also check the bottom part of the roller and housing for anything that could be jammed in there or stuck.
Dec 22, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Red streak poor color
If streaking is occurring only at the bottom of the page (i.e. the last area to print as the paper is fed beneath the print head), the problem may be due to improper curl of the paper. Many inkjet printers (Canon especially), rely on a slight curl of the paper so that it is "bowed" when it travels beneath the print head.
To see if this is the problem, gently roll a sheet of paper so that the print side is on the outside of the roll. When you place the paper in the feed area, it should have a very slight bow so that the center of the print side is slightly raised off the surface, while the edges are on the surface.
Also, make sure you use only OEM (Canon) cartridges. There is not a single "compatible" cartridge in the world that won't screw up your Canon print head. Take my word for it (and I DON'T work for Canon), you must use only Canon cartridges.
Dec 07, 2007 | Canon i850 InkJet Photo Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
old marine
old marine
