Flashing lights cannon ip 1200 printer fashing from green to orange
    Guru:
  • 389 Answers
1. Switch off the printer (the button Power
2. Holding button Resume , include the printer (press the button Power
3. Holding button Power , release the button Resume (the indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press the button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (the indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press else raz.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times podryad.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6 :
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press else raz.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant sb
Posted on Sep 21, 2009
SOURCE:
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Cannon i9900, power light is flashing green to orange
Come back to me with the flash sequence of both lights. that tells you what is wrong. Its more accurate than any error code.
May 28, 2011 | Canon i9900 InkJet Photo Printer
Ip 2000 on button flashes green then orange ,
Needs resetting at best.....perhaps it might shut down completely.....I had the same problem then my printer completely shut down!
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
I70 wont print & Printer Head won't return to the centre
The first error was waste ink near full which you can bypass with resume button, now the absorber is full which means it won't print until you have the drain pack replaced and the counter reset by a shop.
Aug 01, 2009 | Cannon i70 Printer
Canon i6100 light flashes 1 green 7 orange
try this
  • (1) Press Resume button and hold for 1-2 minutes.
  • (2) Open the Cover.
  • (3) Release the Cartridge and then Put them ON again.
  • (4) Close the Cover.
  • (5) Turn OFF the printer.
  • (6) Turn it ON again.
Mar 09, 2009 | Canon Office Equipment & Supplies
Cannon pixma ip1700 not printing
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Feb 13, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Can not print from my Cannon i950. 'paper thikness lever position
A friend of mine had the same problem and turned out to be the print head. They can be pricey so a new printer would be in order probably. Could also be the waste ink counter as well. Here are some steps to see if you can get rid of the 7 orange blinks:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
If this doesn't work then you know its the print head for sure.
Feb 10, 2009 | Canon i950 InkJet Photo Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
101 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
