Question about Sharp Notevision PG-A10X Multimedia Projector
Projector sharp notevision problems with switching off half way through presentation
Where do you get the Lamp power supply?
Posted on May 26, 2008
  • 563 Answers
Does the temp. light come when it switches off ?
Check if all the fans are running when switched on.
If all the fans are running - take out the lamp and check if you can see any irregularity on the shaft of the lamp's insides.
If not then you will most probably have the Ballast ( Lamp's powersupply ) replaced or repaired
Posted on Apr 02, 2008
Connect Sharp PG-A320X Notevision Projector to MacBook Pro computer
well if its the newer Macbooks you will need a thunderbolt to whatever your projector accepts (vga or dvi) so can find those cables at any computer store.
Dec 02, 2014 | Sharp PG-A20X LCD Projector
SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Jul 31, 2010 | Sharp Notevision XG-C50X Multimedia...
    I used the F7/function key to get the presentation on the screen but then, I cannot see the presentation on my computer-help?
    Keep pressing it...3x 1. you will see it at the projector 2. projector and laptop screen 3. just laptop screen.
    Jun 14, 2010 | Sharp Notevision PG-B10S Multimedia...
    Cannot get my Sharp Notevision remote to advance slides
    you need an infrared receiver that plugs into your laptop to receive the signal ...honestly they arn't very reliable...go buy a targus presentation remote at staples for 39-69 bucks if you want areceiver i think i have one left
    Nov 13, 2008 | Sharp Notevision XG-P10XU Multimedia...
    Missing remote control and projector keylock is on
    I think you need remote for above said process.
    Get original Sharp remote for XG-P10XU from Sharp Accessories.
    Nov 10, 2008 | Sharp Notevision XG-P10XU Multimedia...
    Projector problem
    if it is only when the computer is connected, replace the cable.
    Aug 29, 2008 | Sharp Notevision PG-B10S Multimedia...
    Having problems with my sharp notevision XG-C40XE
    Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
    Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
    Projector
    I have a Notevision Sharp xr-1s projector and it wont work with my windows vista laptop. I tried it on my vista pc and xp laptop and it works fine.
    Jun 20, 2007 | Sharp XR-1S Multimedia Projector
    Open Questions:
    See all Sharp Notevision PG-A10X Multimedia Projector Questions
    Sharp Notevision PG-A10X Multimedia Projector Logo
    177 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
