Question about Kenmore Elite 45986 Front Load Washer
Step by step instructions please
We bought our washer used and for some reason the model number was removed (?) as i found out yesterday when serviceman came - they (Sears) will not service without this model number being present so i've got my toolbox ready ... i remove the bottom panel but would like step-by-step please so i can install correctly. thank you so much for your invaluable help!
  • lannb Apr 03, 2008
    Sorry, this was my first time on site and thought i had linked to the original topic. I actually kept digging deeper (on this site) and found out the "how to" on replacing the infamous latch on the Elite 45986 front load washer. Followed the remove 3 screws on the back top of washer off and worked from the top removing the latch and replacing. To share helpful information to others part number was 8182634. It was available in Houston to drive and pick up; also found online to have shipped. Thanks for your reply and the awesome knowledge!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Step-by-step instructions for what? I need to know what you are attempting to do.
    President:
  • 1,294 Answers
Fixya!
Posted on Apr 06, 2008
SOURCE:
Dear sir, we bought some time ago one brandt washing machine model no WFU0811K, which has also drying system. soon after we made a removal to another house and we lost the book of the instructions. now we...
I have found some website that could help. What I done take your model number of your washer machine and do a Google search, and type in instruction manual.
May 05, 2011 | Brandt Washing Machines
Regarding a Roper top-loading washer, model #RAX4232KQ0: the interlock mechanism that controls power cutoff during the spin cycle only seems to be broken/defective. It interacts with the lid of the...
The part you are talking about is called the lid switch. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions do apply. The part number is 3949247 and can be found at appliancepartspros.com for about $23.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Aug 14, 2009 | Washing Machines
Gearcase
The following link gives step-by-step instructions on how to repalce the gearcase on a Kenmore top loading washing machine with a direct-drive transmission:
http://www.fixya.com/support/r699497-replacing_gearcase
To answer your question, "yes", you DO need to remove the agitator. That is explained in step 11 of the instructions. I hope you find this information helpful. If you require additional assistance, please let me know.
PS Any particular reason why you are wanting to remove the gearcase?
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
How does a person take off the top part of the washer to access the lid switch assembly? It is a Whirlpool LXR7244JQ0 washer?
If you are talking about removing the outside washer casing, the following link explains the steps necessary to replace a lid switch:
If you have not purchased a replacement switch, you can do so at searspartsdirect.com. Just type in the model number you provided and look for item number 9 (part number 3949247) under the "Top and Cabinet" heading. This is a very simple repair job if you follow the step-by-step instructions. If you require addditional assistance, please let me know. I hope this helps you.
PS For a cost comparison, you can also try replairclinic.com to see if they carry the switch for less. Use the part number provided.
Aug 28, 2008 | Washing Machines
When on hot water selection no hot water comes out
This an indication that the hot water solenoid in the water inlet valve has failed. If you replace the valve, I bet your problems go away. The following link provides you with step-by-step instructions on how to replace one:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
Please post back with your COMPLETE model number (located along the wash tub opening under the washer lid) if you require parts assistance. I can help you locate them online, or provide you with the a part number. I hope this helps you.
Jul 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore 110.24642300 won't spin
This sounds like a typical symptom of a broken motor coupling. Click on the following link for step-by-step instructions on how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
These instructions will give you the necessary information to take the washer apart to get to the motor coupling to see if it has failed. A tell tale sign is black rubber dust particles under the washer where the drive motor is located. Usually the rubber bushing shears apart, or the plastic tines break off the coupling itself. If the motor coupling is broken a replacement can be found at searspartsdirect.com. Just type in your model number and the coupling can be found under the "Brake/Clutch/Gearcase/Motor/Pump" heading on the next page as item number 13. The part number is 285753A. This is a very simple repair job. If need further assistance, or have any questions please let me know. For quicker responses to your questions, please go to my profile and use the "Ask Me" feature. I hope this is helpful to you.
Jun 21, 2008 | Kenmore 22422 Top Load Washer
Whirlpool duet washer
Assuming that your model number is correct, searspartsdirect.com has the pump for a reasonable price. Just type in your COMPLETE model number in the Search menu and you can locate the pump under the "Pump and Motor Parts" heading as item number 10 (part #8181684). If you need assistance in how to replace the pump, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you do not wish to order the part on line, take the part number provided, and go to your nearest applaince repair retailer. I hope you find this information helpful. Please post back if you need further assistance.
May 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I need help also.
The model number should be located around the tub opening somewhere. The part you are describing sounds like the lid strike and/or lid switch. If you can doublecheck and provide me with a model number, I can locate the parts for you. If you wish to repair this yourself I have step-by-step instructions at the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch usually costs about $25, while the lid strike costs about $10. A repair of about $35 may change your mind about buying a new one. I hope this helps you. Post back if you have further questions, or need more assistance.
Apr 28, 2008 | Kenmore 22422 Top Load Washer
Rubber door seal rip...
The rubber door boot (bellow) commonly wears out on these front loaders. A replacement will run you about $80 just for the bellow. Labor could run as high as $180 if you decide to hire someone to replace it for you. If you wish to perform the repairs yourself, post back with your intentions and I can provide you with step-by-step instructions on how to replace it. It is labor intensive as you will have to remove the entire washer front in order to do the job right. It IS possible, however, if you wish to pursue a repair option on your own. Just let me know.
PS I can also provide you with the part number if you reply with your washer model number (found along the door opening).
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
41 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
