Question about RCA P52926 52" Rear Projection Television
RCA MODEL P52927 HELP PLEASE!!!!!!!
My mother in law gave me a beatiful RCA 52' projection tv model # p52927, only it wont turn on. I have power @ the outlet,and she seems to think a few years back there was a problem with the power switch, is this commom or is there a better way i can diagnose this problem?, there is also no remote with it so i cant verify a bad switch, i took the screen off to inspect the switch for corosion or a broke terminal or wire and it seems to look ok. any ideas?
  • 2 more comments
  • CARMELO380 Apr 04, 2008
    SERIAL NUMBER 014551437
    SERVICE # P52927YX1
    I THINK THAT SHOULD HELP
    THANK YOU.
  • Anonymous May 08, 2008
    TV was working good then all of a sudden just went out. Now nothing comes up, power is good at outlet. No picture or sound.
  • Drew Sellery Dec 03, 2008
    The only thing I get is a quick pop sound in speakers when I plug it in and unplug. None of the buttons work and there is no picture with minimal sound. Please help.
  • rantz67 Jan 01, 2009
    TV was working fine, and then all of a sudden it stopped working. When you press the power button, it flashes green momentarily, but nothing happens.
I have the same problem, except when you press the power button it lights up, but at the when the screen usually pops on everything shuts off. The TV info is..
Model # D52W26
Serial # G272C10BK
Chassis # ITC222
Posted on May 08, 2008
  • 149 Answers
Can you get me chassis number ?
Posted on Apr 04, 2008
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
52" rca projecion tv will not come on i broke it down and there is a faint beebing sound comming from the transformer area
Chances are you have 3 bad capacitors 2200uf 16v cp150/ cp111 is 330uf 35v / cp114 is 220uf 35v they are green with gold writing on them.
Oct 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52927 sound is static
Need adjust coil sound ( little metal beside Big IC or between tuner and IC). Turn a little right and left ( be sure leave same position) don't play with this coil too much, will mess up video signal , some times tuner need be re solder. I hope this will help you Thank you!!!
Jun 30, 2008 | RCA P52926 52" Rear Projection Television
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
RCA model P52927
let me get some info how to get the screen off and I' get back to you... e-mail me networks@q.com
Mar 23, 2008 | RCA P52926 52" Rear Projection Television
RCA P52927 52 in. Projection TV
You have a convergence problem, try unplugging power for 5 minutes. Call factory authorized service center.
Nov 18, 2007 | RCA P52926 52" Rear Projection Television
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
466 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
