Grahpic display driver can not be used cuase it was written for a previos version of windows and is no longer compatible with this version of windows.
    Master:
    Sergeant:
  • 482 Answers
SOURCE:
I have totalmedia 3,5 arcsoft per windows vista, but i need to use it with windows 7. Could you help me? Thank you Gennaro
The router may not be the problem. It may be the compatibility issue.
Here is the article that addresses running older program with Windows 7
Make older programs run in this version of Windows
Most programs written for Windows Vista also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, you can try changing the compatibility settings for the program, either manually or by using the Program Compatibility troubleshooter.
getcontent.aspx?assetid=745c7204-cf9f-46fb-a86c-98d4b9c644cf&documentset=en-us&prod=win700&market=us Go to the Windows website to watch the video. (1:26)
If changing the settings doesn't fix the problem, go to the program manufacturer's website to see if there is an update for the program.
Warning
  • Do not use the Program Compatibility troubleshooter on older antivirus programs, disk utilities, or other system programs because it might cause data loss or create a security risk.
To run the Program Compatibility troubleshooter
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open the Program Compatibility troubleshooter.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
To change compatibility settings manually for a program, right-click the program icon, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 × 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Change settings for all users
Lets you choose settings that will apply to all users on this computer.
Article ID: MSW700015
Jun 08, 2011 | Computers & Internet
Can not reopen Cal Creator 10 On my new windows 7 computel please help
Make older programs run in this version of Windows (from help section in Windows 7)
Warning
Tip
?id=microsoft.windows.resources.collapsearrow?id=microsoft.windows.resources.expandarrow To change compatibility settings manually
Setting
Description
Compatibility mode
Run in 256 colors
Privilege level
Dec 18, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
When I open the Display Settings dialog box in Microsoft Windows Vista Home edition, I am receiving the following error message: The currently selected graphics display driver cannot be used. It was...
this means that the driver that you installed on this os which is windows 7 , that driver is not compatible with windows 7 and you need to uninstall it After uninstalling the driver , please download the latest version for the same driver viz compatible with windows 7 .
Let me know your pc details , like the model number or the model number of your display card ?
Thanks..
Nov 18, 2010 | Computers & Internet
EliteBook 8530w display settings/ drivers issue
Have you installed the latest and appropriate driver for your notebook, i doubt.
To get the latest driver please Cick here
Open the link above and select the video driver, remember u need to uninstall the previous driver first.
Please feel free to ask me for further assistance.
Mar 29, 2010 | HP Elitebook 8530w Mobile Notebook
Driver not support for windows 7
Try installing the driver in compatibility mode.
Instructions:
right click on the setup file --> properties --> goto compatibility tab --> click on the check box showing " Run this program in compatibility mode for" --> chose previos version of OS(xp, vista etc...) of ur desire ---> press ok
now run the setup file...
Thanks.
Feb 28, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Can not run on windows xp
Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. These programs may run poorly or not at all after you first upgrade to Windows XP. You may have heard this referred to as application compatibility issues or program compatibility issues.
You should run the Program Compatibility Wizard before you try other ways of updating your programs or drivers because it identifies compatibility fixes written specifically for Windows XP.
To run the Program Compatibility Wizard:
1.Click Start, and then click Help and Support.
2.Click Fixing a problem, and then click Application and software problems.
3.Under Fix a problem click Getting older programs to run on Windows XP.
4.Read the instructions and then click the Program Compatibility Wizard.
Update Your Program or Drivers
If your program does not run correctly after testing it with the Program Compatibility Wizard, check the Web site of the program's manufacturer to see if an update or patch is available. Also, go to Microsoft Update to see if a fix is available there.
If the program is a game that uses Microsoft DirectX®, make sure that you’re using the latest version of Microsoft DirectX. In addition, check the Web site of the manufacturer of your video card or sound card to see if newer drivers are available for either of them.
I hope this helped!
if you need any further help please contact me
Please don't forget to vote.
Jun 21, 2009 | GT Interactive Bedlam for Windows, Mac
This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
  1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
  2. Update your program, drivers, or hardware.
These options are covered in detail below.
The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
Dec 19, 2008 | Computers & Internet
Dell Latitude D600 Display problem
Go to support.dell.com under drivers select your system download the latest video driver,or on you c drive on your computer you should have a folder called dell where you will find the original drivers for your computer.Install them that will take care of your problem.
Good luck
Dec 12, 2008 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Radeon FSC Graphics Display Driver
Go to this link armed with your exact model number(if you can't find this in windows device manager then easiest is to look on the card itself - unplug the pc first and don't touch anything inside unless you know what you are doing) then you can download the correct driver for your operating system if the card is compatible. Follow the download and install instructions and you should fix the issue. http://support.ati.com/ics/support/default.asp?deptID=894 If you need more help with this then please post again with your ati model number and your operating system version. Hope this helps :)
Mar 18, 2007 | Fujitsu ATI RADEON FSC (64 MB) Graphic...
Open Questions:
Computers & Internet Logo
23 people viewed this question
Ekse
Alun Cox
