Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony LCD Projection TV turning OFF!!!
Hi, My SONY TV keeps turning off at diff time intervals. The light flashes for like 6 times and then it stays off and we have to turn it back on. What could be the problem? Is is something we could fix ourselves??
Thanks so much!!!/ Kat
  • kmorris May 13, 2008
    My Sony KDF-42WE655 stays on for two minuest then shuts off and the green light blinks 30 times then it comes back on. We just replaced the bulb in March. We have tried resetting. Any ideas?
I also have a Sony KDF-42WE655 42" Lcd television. We just changed the lamp (bulb) several weeks ago and has noticed that everytime we turn on the television it stays on about 30-40 seconds then cuts off. After about 15-20 seconds it cuts itself back on. Weird!! It must have something to do with changing the bulb!?!?
Posted on Jun 09, 2008
  • 59 Answers
The six blink code is caused by a power fil on the G1 POWER BOARD. THE MOST COMMON PROBLEM IS THE SOFT START RELAY MAKES A POOR CONTACT. REMOVE RELAY, BURNISH CONTACTS AND REINSTAL, THIS WILL CURE THE INTERMITTANT SHUT DOWN.
Posted on Jun 12, 2008
I also have the same exact problem with my KDF-E42A10. I have puled the lamp out and it does not appear cracked or dusty I put it back in and it still shuts down every minute and then restarts. I am very frustrated with Sony as this seems to be a frequent problem. HELP!!! Any solutions for me. I do not think that the lamp is broken as the picture is fine for the minute it works before it shuts itself down.
Posted on Jun 17, 2008
Problem with Sony Grand Wega TV
This could be due to bad capacitors in the sweep supply, a bad High Voltage block, a bad regulator.
Jul 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony tv not turning on
I would need the model number to look service codes
Feb 24, 2008 | Televison & Video
Sony Grand wega lcd projection tv Hd/Tv Help troubleshooting
Did you clean the air filter? Sounds like a thermal problem due to a plugged air filter.
Jan 17, 2008 | Televison & Video
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
472 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
