Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer Won't Fill
I reversed the hoses and I got too much water in the tub so anything else you think it could be. I am now getting a LF code when trying to use it.
  • Kacosta Apr 19, 2008
    HI,
    I get a LF code two different scenarios. It has something to do with the hot water. When I wash Hot/cold rinse no water comes into the machine. When I wash Warm/cold rinse the machine stops at the point where it changes to rinse (I thought the water was warm but apparently the water is 100% cold. Is this a solenoid issue?
    President:
  • Whirlpool Master
  • 2,651 Answers
Ok at first you got no water, by simply reversing the hoses now you get to much water?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display
was trying to find how the hoses are supposed to be, im thinkin the should kinda fall in the rigth position as to which side shoudlbe which. if you set to spinn only does the water now drain out ?if not then the hoses are definelty reversed now, which would put us back to the original issue
Posted on Apr 03, 2008
SOURCE:
What does the LF code mean?
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
  • Is water supply connected and turned on?
  • Are hose screens plugged?
  • Is water entering the tub? If so check pressure hose connection to machine/motor control.
  • See TEST #2 in manual
Jun 20, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Whirlpool LF Error code
LF = Long Fill
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
Im receiving the LF code what does this mean??
Check that the drain hose and water inlet hose are properly installed, and undo any kinks or clear any clogs if the display error reads "LF" indicating that the load is taking too long to fill, or "Ld" indicating that the washer is taking to long to drain. If the code reads "HC," the hot water hose is installed in the spot for the cold water hose and vice versa.
Also, check this information from Whirlpool DataBase: Display shows LF
Hope helps (remember to rate and comment this answer).
Sep 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Washer starts then gets LF code
rwer
Hello and sorry to read about you LF issue
LF means long fill. Turn off the water and remove the hoses from the back of the machine, inspect the screens inside the washer water valve for debris. Stick the hoses into the washer tub and turn the water on, verify you have good water flow. If all of this checks ok then you either have a bad water valve or the control is sending power to the secondary diverter valve but not the primary hot/cold valve or vise versa.
I tried to help you.Please help me and rate/vote my response
Thanks and good luck
Dec 24, 2010 | Maytag Bravos MVWB400V Washer
"LF" Long Fill Fault Code on Whirlpool Cabiro HE Washer
there is an electronic timer, did they mention how long the fill should take on average and when the timer signals fill time exceeded?
Sep 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
