Fencing woven fence installation
  • Anonymous Apr 09, 2008
    I think I am at the wrong website for the problem.
  • Anonymous May 11, 2010
    ...I'm sorry, can you say that again? Preferably with more information as to the nature of your problem.
I am trying to install some heavy duty mesh fence to round fence posts. The corners are difficult because the posts were to far apart(11') to use the same 3.5 diameter that I use for the post for the corner rails. The best thing I found for it was 3.5 in square after doing a lot of research. Now I am not sure how far above the bottom of the pole to install it. I was going to use lag screws to screw it threw the fence post into the square top rail. Where should the top rail be in relation to the top of the wire mesh? The mesh is 4' high. Right now I have a 2" gap.
Posted on Apr 09, 2008
6ya staff
SOURCE:
I am installing Everbilt 4-ft. wire fencing using Everbilt 6 ft T-posts. So far, I've not been able to generate the desired tension in the fence itself.
fencers will tell you that a tight fence breaks easily and it is not advisable to have it too tight
wire used is not high tensile wire
the intervals are too far apart at 8 ft for a stable fence and the distance normally is 6ft
the method to get a good fence using wire strands is to roll the wire roll out as that lays the wire out straight and not pick the wire up off the coil which twists the wire and makes it near impossible to pull tight
Aug 17, 2018 | Cars & Trucks
Zareba 5 mile solar fence not putting out power with new battery installed
Any electric fence will have no power if weeds or long grass is up against the fence itself. We even had a big thistle that shorted out our fence and there was no shocking power in the fence itself.
Jun 19, 2018 | Solar Electrical Supplies
How to install a fence?
Waht fence do you want to install. Is it a boundary fence? I ask because a radial arm saw also comes with a fence. It is always better to give too much info than too little.
Oct 16, 2017 | Saws
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
I need some kind of fence with at least 1 gate. I have vinyl fencing on both sides in the back yard, but it's only privacy fencing to separate the yards. I have 2 small dogs and I can't let them out i
You could probably continue the vinyl fencing but that will cost a lot. You could always use a chain link fence which is really cheap and easy to install but it won't look right.
Aug 08, 2013 | Sport & Outdoor - Others
How much should a wooden fence cost?
Of course it depends on the dimentions of your yard. Wooden fences can be quite expensive. look at this site, it includes installation costs:
http://www.homewyse.com/costs/cost_of_wood_fencing.html
Jan 31, 2013 | Home Fencing
What is the best fence I can use for my dog?
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...
don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Open Questions:
Computers & Internet Logo
160 people viewed this question
Ekse
Marvin
Marvin
