Question about Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio
Cobra microtalk2 auto squelch not functioning
I have a cobra mircotalk2 frs radio, the auto squech is not functioning. although i could hear week signal but it is annoiying a lot of times specially when other people are around. could you help me up on this. thanks. my email is: [email protected]
  • 91 Answers
Dear sir,
Use maximum range button which is also light button ( keep it pressed for 5 sec ) u will hear a beep , then relase it operate ur radio in High power transmission mode , ( channel 1~7 ) or 16-22 ( ckeck ur country lcense guideline before that ) .
Regards
Raj
Posted on Apr 12, 2009
SOURCE:
Loud crackling noise
The monitor function is turned on, on the unit that is noisy.
The manual describes the procedure for setting the monitor function the manual is available here.
https://www.cobra.com/support/product-manuals
May 11, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
Can a Motorola talk about 250 talk to a cobra CXT 195. They can hear me from the Motorola I just cant hear them
Your code (PL code, interference eliminator, quiet call) is not programmed the same on both radios. The Cobra appears to be set to open squelch (no code). Set your Motorola code setting to zero (off). This should solve the problem.
Feb 18, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
COBRA MICRO TALK1 FRS 100
THEY SHOULD ALL WORK TOGETHER ON THE FRS FREQUENCIES. MAKE SURE THAT YOU SET THE CHANNELS AND SUBCHANNELS TO THE SAME ON ALL FRS RADIO.
Oct 07, 2012 | Cobra Frs-120 Microtalk 2-mile 14-channel...
I have 4 radios. Initially they all worked together. Now , een on the ame frequency , they do not all pick up the signal? Any ideas why?
These are FRS/GMRS radios. You may have different privacy codes set on the radios. If a receiving radio has a different privacy code than a transmitting radio, you will not hear the transmission. This allows many people to share the 22 channels, but only hear transmission from their party.
Nov 11, 2010 | Cobra 22 CHANNEL 2-WAY RADIOS
One of my walkie talkie has an RX on the display and you can send but you cannot hear the other person. How can I remove the RX as that seems to be the only difference in them. Thank you
depending on what radio you have, they are programmed in different ways, rx means recieve signal
and tx means transmit signal, if you have a mode button, you will have to scroll through it until you
get to the menu that allows you to change the radio transmission. it looks like that radio is only
programmed to receive signals and not transmit. good luck!
Nov 11, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
It says it goes up to sixteen miles but i was only a block away when it started breaking up
usually its 16 miles on a clear piece of land with no trees or hills ect, if you have lots of trees there probably interferring with the signal.
Aug 22, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra microTALK LI6000-2 (14 Channels) 2-Way Radio Logo
255 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
