Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Web cam set up on Canon IXUS 400/POwershot 400
\Pls advice on how to set up web cam using my Canon Powershot Ixus 400/ IXUS 400
Cheers,
Sid
For any self respecting programmer/hacker, the instructions at http://users.utu.fi/paanni/camera.html maybe close to what you want.
Posted on Oct 22, 2008
I was just surching the internet for the same thing. On an English language webpage I didn`t find any solutions. But on a German website, www.ixus-word.de, I found a solution. It said ther that first you´d need the VisionGS v1.21f plug in. That is available for free in the internet if used for privat purpose.Then you have to connect the camera by video cable. That is important because it wouldn´t work by USB. The information said, that any other software is included in the package that came with the camera.
Posted on Aug 10, 2008
  • 4 Answers
Can says it can't be done on their support website as the webcam has not been implemented.
https://self-service-kb.canon-europe.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=68,E=0000000000429774916,K=2059,Sxi=0,Case=obj(7638)
Posted on Jun 18, 2008
I have the same question can someone plz answer
Posted on Jun 13, 2008
SOURCE:
Web cam used
I think the best solution is to tell everyone what the actual problem is not by saying web cam used
Sep 21, 2013 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Canon ixus 400 user manual
The IXUS 400 is called the PowerShot 400 in some parts of the world. You can download the S400 manual (and more) from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_g_series/powershot_s400#BrochuresAndManuals
Feb 08, 2011 | Cameras
PowerShot S400 / IXUS 400 Digital Camera: I need a user guide for my Canon ixus 400, any ide...
The IXUS 400 is called the S400 in some parts of the world. You can download the S400 user guide and more from the manufacturer's web site at
May 18, 2010 | Canon PowerShot S400 / IXUS 400 Digital...
Hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Jan 14, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
CANON FAULTY SCREEN IMPORTANT READ ME
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Oct 02, 2007 | Canon PowerShot SD100 / IXUS II Digital...
As a webcam
No I am afraid you cannot use this as a web cam. I have asked Canon about this and they said that it isn't capable. Sorry
Aug 22, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
FLASH WONT WORK
non for you to do that is. Canon support may have some advice - if the camera is of any age - then a new camera may be the best bet.
Mar 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
583 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
