Missing VGA Cable for LCD Monitor - Help?
Hi: I read your answer to the missing VGA Cable for the LCD monitor and was wondering if I take a VGA Cable from a CRT montitor and swap out the white 28 pin female connector from inside the monitor while matching the pin wires to those listed in your last post should it work?
  • bosspr44 Aug 10, 2008
    My vga cable is broquen and i need the pinout of cable
  • 180 Answers
It should be 15 pin connector VGA .It should work.
Posted on Apr 19, 2008
    New Friend:
I want to Re instal VgaCable For Hp Lcd L1502 Please sulution any crt vga cable How to instal to lcd l1502
Posted on Mar 18, 2013
Hp monitor vga cable wiring solution
Hi,Sir/ i have lcd monitor Hp-L1502 its on position wen i start lcd without vga cable to frount lokation is red+green+blue colours step by step fliker&i can fix new vga cable.whats sulution?
Nov 10, 2011 | LG Studioworks 700S 17" CRT Monitor
Acer X193HQL LCD Monitor Colour Problem
Hello Sales, hi, try to reconnect the VGA cable from the PC, and wiggle it a little and see if the green tinge thing disappears on screen, if it does there are loose contacts, you can also try to replace you VGA cable, see if it solve the color problem.
Apr 27, 2010 | Acer AL1912 19" LCD Monitor
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Hi, I have a Compaq 1701 monitor and the video signal is missing, but you can see the background; the system (Pentium 4) and the VGA cable are OK; no OSD; please help me!
The fluorescent lamp has failed.
The LCD monitor has a "backlight" in order to illuminate the video images that you see.
It may be too costly to repair, since it may break again after repair.
New LCD monitors start at just under $100.
Quick fix, if you are brave:
With an open palm (not the PDA), whack the side of the monitor gently or not so gently to see if it works.
If so, you can either replace the monitor or put up with a sore palm.
Sep 29, 2009 | HP Compaq 1701 17" Flat Panel LCD Monitor
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
Black screen on monitor
this will be the onboard VGA adaptor ( driver Missing Corrupt ) there are a couple of things to Try.
1:- remove power from Computer, Locate the Cmos battery ( small round battery that stores Bios Info ) remove battery for 10 seconds. replace. power up and boot.
2:- If your computer has an onboard graphics card Slot. AGP/Pci-express. add an additional card, and attempt to run on that card. to boot the computer, enabling you to re-install the corrupt/missing vga driver.
thankyou for using fixya.
Mike @ Compurepair.
Jul 20, 2009 | Computers & Internet
15''lcd monitor cable problem.
Hi, this may not be solution for what you ask but rong signal can or mayset u monitor on flames it hapined to me, why? hold on to old cable whan you can go and get new one, if you say you cant find, then get a moltetester chack the each ends pin to pin for contanuity. good luck
Jun 22, 2009 | Computers & Internet
Just acquired a TCO 99 monitor but the DC12v 3.0A
brucemeyer, Are you missing the Whole "lay on the floor black box switch mode power supply" thing, and not just "a cable"? Gee, those monitors aren't very good without their DC voltage source!!
You could always use a car battery, but then all you need to do is figure out where positive and negative plugs into the monitor. Remember This IF you get it Wrong, you could DESTROY the monitor forever!!!! The best bet for you will be to contact Taxan service and get a recommended substitute SMPS brick supply. Hmmm???? I wonder where the original went? I'm louie12fix on fixya or lmistyrel@ aol.com
Bye for now.
Apr 23, 2009 | Taxan Crystalvision 680 TCO 99-S 15" LCD...
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Computers & Internet Logo
710 people viewed this question
David Payne
David Payne
