Have a new samsung lcd tv la46f81bd have sound no picture just all color ed lines and dots
    Problem Solver:
  • 12 Answers
Check your book out, could be the lamp. Warranty?
Posted on Apr 02, 2008
SOURCE:
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Samsung ln22a450 no picture just audio in the back
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Samsung LN22A450 22 in. LCD HDTV
I have a samsung LCD TV that is now having colored dots and verticle lines on it. It also will have red dots and dasheds that with be on anything that is dark colored. What could cause this
Hello:
This may be due to a faulty T-Con board that needs replacing, this board is the display driver and will cause all type of symptoms when it is going bad.
Jul 08, 2011 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Green lines, color dots , colored lines whats wrong?
Is it an LCD display? Coloured dot`s are dead or stuck pixels and lines are usually the lcd panel controller failing.
John
Dec 02, 2010 | Computers & Internet
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
Colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Mar 10, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
I bought a Samsung 46" LA46F81BD today pluged it in and tune the tv. The picture was great after about 30 minutes the TV went blank and lost picture. I still have audio. does anyone know what the...
If this is a projection TV,you may have suffered premature lamp failure.If it's an LCD,could also be a backlight lamp failure.Either way,it should be under warranty if it's new.
Mar 13, 2008 | Televison & Video
Samsung LN-T4065F Dotted lines across screen
tell the idiots where u bought this tv from and demaand a more expensive and better tv on their bill
Mar 02, 2008 | Yamaha DV-S5950 DVD Player
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Ekse
