Question about Canon PIXMA iP4200 InkJet Photo Printer
Only prints in magenta
My printer only prints in the magenta colour. All of the cartridges have ink in them.
Suggestions for a fix?
Thanks
    Problem Solver:
  • 15 Answers
If your cartridges are new one then do this, reinstall printer driver and check in the printer driver features that you have selected print in black and colour option
Posted on Apr 29, 2008
Souk the cartridge in hot water... just did it today and it worked
Posted on Apr 30, 2008
Printer only prints in one colour magenta
Hi, When that happened to me it was the color ink cartridge that was the problem, apparently it was empty. A new cartridge and up it came.
Dec 30, 2014 | Cannon Office Equipment & Supplies
HP C6180 all in one printer My printer will not print light magenta and magenta, all the other colours are fine. Tried everything Any suggestions Thanks Paul
This problem seems to be with the printheads of the printer If magenta ink cartridge has enough ink inside it and if print heads are damaged then you need to replace this printer.....
But still if u want you can follow the below mentioned steps :
If it is not printing in light magenta and magenta than you can try the below mentioned steps :
Step 1 - First clean print heads from the menu of the printer. You can look for clean printhead option under printers menu - Tools - Clean Print Heads.
Now print and see if it is printing or not. If issue is not resolved then move on
Step 2 - Check if your magenta ink cartridge & Light magenta ink cartridge has ink in it or not...if it is empty or if has very low ink then.....
replace it with a new ink cartridge......and now it is going to aling the printer....While it aligns it is going to make noise and will show a message printer aligning or alignment in process.
While it aligns dont touch the keys of the printer or dont interrupt in between the process otherwise hardware of printer might get damaged and you have to replace the whole printer
...and just wait...till the printer display shows the regular menu...
Note : - * During Alignment printer is going to consume more ink, so make sure you have enough ink in all the cartridges or otherwise it does not have enough ink in it
alignment process will not be completed properly.
Steps 3 - If it prints an alignement page then it is ok, check if all the colours on the alignment page and if all the colours are fine then ur issue is resolved...
for verifying you can print another document.If it does not print any alignment page then you can try printing an alignment page from the printers manually from the printers menu.
Now if it has resolved the issue then it is fine or else last you can try re-setting the printer.
Re-Setting the printer :
- Press and hold the "*" key.
- Press the "#" key and release both keys.
- Display should say "Enter Special Key Combo" then release the keys and press "1", "2" and "3" buttons in sequence.
- then you will get few options, now look for an option that says System Information or System Menu
- Press "OK" on System menu and look for an option Semi full re-set
- Press "OK" Button.Now printer will shutdown automatically and will turn on automatically after few seconds..as it is going to align the printer..
- Now it will make noise for few minutes wait till then and when you see regular screen on display then print a document and see if issue is resolved or not.
If issue is not resolved then you need to replace the printer. If it is in warranty then contact Hp customer care and they will replace it for free.
Feb 25, 2011 | HP Photosmart C6180 All-In-One InkJet...
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Why is it that my printer won't work if one ink cartridge is empt
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Mar 31, 2009 | Epson Stylus CX7000F All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma IP4300 - cartridge recognition preventing any printing happening.
I seem to be having a similar problem with my cannon pixma 4300 as certain others, i have just recently replaced all the inks with " original" cannon inks and all of a sudden it refuses to print anything, it says that one of the inks is not working, ( Yellow) I remove it, replace it again and the light comes on but when the slide retracts the light seems to go off. any ideas would be great, this seems to be a fault i have read a few times.
Aug 11, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Pixma iP1500:new ink cartridges fitted but no Magenta
Take a look at the mounting point. They break very easily on this model. If not broke, try cleaning with a swab and inserting the cart again.
Jul 03, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
88 people viewed this question
old marine
old marine
