I'm assuming that the engine continues to run, but the chain stops moving. Remove the bar and chain. If the clutch internals are full of bar oil and other debris, try washing out the clutch with spray carburetor cleaner from an auto parts store. After it dries, inspect the shoe faces and inner drum area for excessive burning or scoring. Apply a small amount of oil to the clutch hub bearing, then reassemble the bar and chain. If the chain now cuts correctly, you are home free. If it doesn't, then the clutch will need replacement. Hope this helps!
