Whirlpool AWZ412 wont spin seems to do everything else have tried with an empty machine but still no spin
    Genius:
  • 1,198 Answers
The first thing to fail on a washer is the lid safety switch. It's right under the top, a little tab on the lid pushes it. Lift the top, check the switch. To test it: temporarily connect the two wires to it together. If the machine spins, replace the switch.
Posted on Apr 03, 2008
SOURCE:
Whirlpool awz 412 not spinning
You will need to replace the motor control board. It is malfunctioning on the high speed control.
Apr 24, 2012 | Whirlpool AWZ412 Front Load Washer
Our Whirlpool AWZ412 washer/dryer just stopped during the wash cycle. It did seemed to have moved 5 cm out of place, possibly due to a disbalance during the cycle. We tested the outlet, swiched the machine...
This could be the door latch switch that has failed or came loose, it may also be that the off balance load caused such a bad vibration that the wires have come loose or broken to the motor.
Dec 15, 2017 | Whirlpool AWZ412 Front Load Washer
Whirlpool AWZ412 (1200): How do you remove the soap dispenser? I need to clean the water inlet holes above. I've tried lifting it and squeezing it. But there seems to be catching on the left side, and...
This is a common problem with many machines.
Try the following- in the second and third cases whilst looking from underneath!
Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit).You may have to push the bottom of the dispenser upwards.
  • lift upwards on the tray as it is coming out to clear the lip underneath. Again you may have to push the bottom of the dispenser upwards.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 15, 2011 | Whirlpool AWZ412 Front Load Washer
We can not pull out the detergent tray on our Whirlpool awz412 Washer
it takes a lot of force to pop the tray out. My advice is when you get so stressed you want to snap it off, STOP, walk away for a half an hour and come back to it later with a cool head. It comes out by just pulling it hard, it feels like you are going to break it, but u wont. The catch is located on the underside of the tray and is a solid part so it wont break.
Jul 18, 2011 | Whirlpool AWZ412 Front Load Washer
Whirlpool AWZ412 No Instruction Manual - Dryer
https://www.2instructions.com/search.php?cmarque=WHIRLPOOL&modele=AWZ%20412-1250
Sir, go there and fill the related blanks and order online. EX:- Fill the description with " Front Load Washer " and E-mail section with your E-mail address. Thank you.
Sep 18, 2009 | Whirlpool AWZ412 Front Load Washer
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
