Question about GE Profile Spectra JGBP85 Gas Kitchen Range
Ge spectra have you ever seen both igniters go bad and neither of them glow ?
  • 1 more comment
  • GRYBASMP Apr 03, 2008
    THAT IS CORRECT ,IT IS A DIGITAL TYPE.
    I CANNOT BELIEVE IT IS NOT WORKING ,, IT IS FAIRLY NEW BUT OUT OF WARRANTY. WHAT DO YOU SUGGEST ?
    MIKE
    I UNDERSTAND YOU VERY WELL,,
    CAN I CHECK THE VOLTAGE READING AT THE IGNITER TERMINAL WHEN I SET IT ON BAKE OR DO I HAVE TO TAKE THE PANEL OFF THE CIRCUIT AND TEST THERE ?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Anything is possible, but I can't say I've seen this situation occur before. Is your oven controlled by an Electronic Range Control board? This may be a problem associated with the control and not the igniters. Post back and let me know.
  • 5,911 Answers
First of all, double check your operators manual settings to ensure your oven is not set to "Sabbath" mode. If this mode is set, it will disable the oven features. Sometimes this mode can inadvertently be set if you experience a brief power outage, or accidently push the wrong buttons.
Now...if it's not as simple as that you will need to check to see if your igniters are getting the proper voltage. It's kind of hard to do this without seeing your wiring diagram, but I would check to see if the igniters are getting the proper voltage from the control board, first. The easiest way (I'm assuming) would be to trace the leads from the igniter to where it connects to the electronic range control (ERC) board. This a GE, correct? Since this is a GAS oven, I'm also assuming the source voltage is 120VAC. If the circuit board is showing a proper display, that tells me you're getting proper line voltage to the circuit card. There should be a separate circuit for the BAKE and BROIL functions. They should work independent of each other. When you set the oven to BAKE or BROIL, you should hear a relay click as the circuit energizes (that is...most of the ovens I've worked on you could hear a relay, I don't know about yours). If you hear the relays clicking on the circuit board for each function that tells me each circuit relay is working. A voltage at the output of each of these circuits should indicate approx. 120VAC. NOTE: It is recommended that you take voltage readings by checking from NEUTRAL to the HOT TERMINAL.
Have you physically checked each igniter? The igniter bar should be intact and not broken. Unplug the range and locate the igniter connector plug by tracing the two wires. This will either be an actual plug, or wire lugs. Disconnect each igniter and perform a resistance check on the leads connected to the igniter. The resistance reading should be fairly low (usually close to a SHORT). If it reads OPEN, the igniter is bad.
Now...this may seem a bit much. If you get confused, please post back and I will try to guide you in the right direction. Good Luck. I hope this helps you.
Posted on Apr 03, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 03, 2008
    If you are talking about checking at the end where it connects to the igniter, you can do this, but it may be a bit more inconvenient. You will probably have to unplug the range, disconnect the connector plug or terminal lugs and connect a meter to the end of the wires coming from the control board. You will need to use care that the wires (if disconnecting from terminal lugs) do not touch anything when you plug the range back in. I do not know how accessible your igniter terminal plugs are.
  • Jeff Rockwell
    I would recommend checking at the control board.
Why doesMy GE gas range broiler and oven not ignite?
When my oven had this problem it turned out that the ignitors for both the oven and broiler had gone bad - yep, both of them. You can tell when an ignitor is bad if it doesn't glow as the oven is started.
I posted some pictures here (I think my answer is #10):
Check out this solution to the GE Profile Spectra JGBP90 Gas Kitchen...
Of course the design of your oven might be different but I suspect the repair would be very similar. Regardless, check to see if the ignitor is glowing.
Jul 08, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a ge spectra gas range and the broiler works but oven wont work?
Check to see if the igniter glows white hot. The igniter needs to be glowing white hot before it will allow the valve to open and lite. Here is the part to order if you find it bad. Post back the results.
Feb 05, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
New broiler igniter glows but gas is slow to ignite
try cleaning the burner some of the holes might be blocked use the end of a paper clip large one
Feb 14, 2010 | GE Profile Spectra JGBP86 Gas Kitchen...
GE Spectra gas stove
Hi, There is a glow igniter that has to glow and open the gas valve to ignite the flame.
Are you seeing any glow below the floor of the oven? Remove the floor on=f the oven and you will see the igniter. If you have a voltage meter, You can remove the ignitor from the manifold ans test it. Put your meter leads into the connection and turn the oven on, (ONLY long enough to see if you have 120V.
If there is voltage, replace the igniter. They can still glow but be bad. The igniter gets weak and will not open the gas valve. Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Trouble changing a glow igniter on a GE Spectra xl44
Your replacement should have come with wire nuts.
Unplug the range.
Snip the wires and strip them back 3/8 inch and attach the wires from the replacement ignitor.
Feb 21, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven won't light
Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
Nov 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85 Gas Kitchen Range Logo
404 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
